Air Compressor Math Problem
/ Air Compressor Math Problem #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
My air compressor makes 15.2 acfm at 175 psig. But it isn't stated how much cfm's it can make at 90 psi. I'm guessing it can deliver more cfm at lower pressures.
Anyone good at math?
/ Air Compressor Math Problem #3
P1*V1 = P2 * V2
so 175*15.2 / 90 = ~29.5 cfm
/ Air Compressor Math Problem #5
When I follow your link and look at the specs. I see;
CFM at 90 PSI 15.4 CFM
at Max. PSI 15.2 CFM
It is a two stage compressor so its not losing a lot with the pressure increase.
/ Air Compressor Math Problem #6
P1*V1 = P2 * V2
That is a static environment equation and not anywhere close to describing a compressors output. Just like P1T1=P2T2. Pumps always have a pump curve. More pressure = less flow and vice versa.
/ Air Compressor Math Problem #7
What compressor do you have? You have acfm (actual cubic feet/minute) listed. Normally, compressors are rated for SCFM (standard cubic feet/minute). Barometric pressure, temp and relative humidity have to be factored in for the conversion from ACFM to SCFM.
I have the one referenced by IH344.
I could call the manufacturer but I'm pretty sure the girl that answered the phone would just read the published specs. back to me.
Will lower pressures produce a higher cfm?
/ Air Compressor Math Problem #9
From all compressor specs that I have seen that rate at different pressures, YES.
But don't ask me how much.
/ Air Compressor Math Problem #10
In reality, not by much. CFM is cfm, the compressor pump displacement is rated for x cfm. that's why I was asking about acfm. Standard cubic feet per minute determines the weight of compressed air at 14.696 pounds per square inch, 60 degrees Fahrenheit and zero percent relative humidity, at sea level. Corrections should be made based on where the equipment was manufactured, although I 'd bet some of them cheat and just use the compressor head specs. regardless of rpm input.
Acfm calculations try to account for pressure, humidity and temperature as the gas (air) expands and contracts. As temps fall it contracts and expands as they rise.
Anyway, these are both measures of flow derived from inlet conditions. So, you have the displacement, now the flow will be determined by your local conditions for inlet density. Will your air tools notice the difference, well that depends.....:p
This may help SCFM versus ACFM and ICFM
/ Air Compressor Math Problem #11
There’s two stage 175 psig Northstar at Northern tool that’s rated at 15.5@ 90 and 17 @ 40.
Thanks, that helped
From the factory reviews....as I figured, not much help.
Question
What is the SCFM at 90 PSI? I understand the CFM; however, the SCFM is not listed and hopefully will be at or above 12.6
Answer
The SCFM is dependent upon several variables, such as, air temperature, humidity level and sea level.
/ Air Compressor Math Problem #13
How about finding out what manufacturer for you pump, it's model number, the rpm, and go from their. The manufacture should know the numbers.
/ Air Compressor Math Problem #14
Thanks, that helped
Question
Answer
based on their acfm data, scfm would be 11.8. What kind of tools are you using? Aren't they listed as something like 4 cfm @90 psi?
http://www.industrialairpower.com/wp-content/uploads/Air-Compressor-Consumption-Charts.pdf
My largest cfm use tool would be the blowgun, or as I sometimes jokingly refer to as a pneumatic broom. So, no special need for high cfm's, just curious is all.
/ Air Compressor Math Problem #16
Your issue is a 175 psi compressor is a two stage one in order to achieve 175 psi.
With normal home shop compressors, you get two flow rates but because these compressors don't reach anywhere near 175, psi you don't suffer the inefficiency of a two stage and the pressure volume relationship is much more linear.
Compare the size of the 175 psi compressor cylinders. One large one feeding a small one. Lowering the pressure does not remove the fact that the compressor has a small and large cylinder and thus suffers from the lower efficiency of a two stage.
Delivered CFM 22.1 CFM @ 100 PSI / 16.2 CFM @ 175 PSI
Single stage compressors good for about 135 psi may have two same size cylinders to increase the volume output
Dave M7040
2000 Komatsu D61PX-12 (A64126)
2000 Komatsu...
2015 John Deere 5055E (A64126)
2015 John Deere...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2012 Ford F-250 6.7L Diesel, 4WD (A62679)
2012 Ford F-250...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
