Air Compressor Fittings.
/ Air Compressor Fittings. #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have two different npt 1/4 inch fittings for my air compressor. But they don't seem to be interchangeable. The one with a thicker collar needs to be forced a little more. What is the different name of these two fittings? Since I am in quarantine, I need to buy them online. 20200427_140432.jpg
/ Air Compressor Fittings. #2
Qual;ity Control?
I have never seen fittings that similar, if they are supposed to be different. What do YOU think they are?
/ Air Compressor Fittings. #4
I know for a fact there are a few different types of air hose fittings, and you have to buy the matching one's to fit. apparently, there's no standard for some odd reason!.. BTW, forcing it in is not good!. look here for a few types. McMaster-Carr
/ Air Compressor Fittings. #5
I only use Milton and get them thru home depot price seems to be the best around...
/ Air Compressor Fittings. #7
The one on the right is an I/M fitting which is the most universal. Not sure what the other one is
Just buy new I/M fittings and toss the other style. Fittings are cheap
Edit: I/M stands for Industrial/M. It’s Milton industries “Industrial” fitting and is the most commonly used in the USA
/ Air Compressor Fittings. #8
I have hundreds of "M" fittings that I decommisioned. I never saw different styles or had issues with connection. BUT, I changed to "A" I think. Don't know, got them all out of one Shut Down Manufacturing facility and it's the one all the Industry around here uses. I switched, because I much preffered the one handed connect feature.
/ Air Compressor Fittings. #9
You can get the M style one handed also .........
/ Air Compressor Fittings. #10
I hear you there Timberxx. I have five different "tools" for my compressor. Air nozzles, tire chucks, etc. I took the fitting that fit best into Spokane to the House of Hose. They specialize in all things - air compressor. They matched with four new fittings. Success.........
No doubt - this is one area where there is no such thing as standardization. All five of my tools had a different end connector fitting.
Awesome guys. Thanks!
/ Air Compressor Fittings. #12
I switched all of my fittings to Milton type M last year. I had a mixture of several name brands and they always seems to have slow leaks and difficult to connect. Now I have 2 coffee cans full of used fittings, and nice quiet Milton M connections on all hoses and tools. I got my Milton fittings at Rural King because they were handy but HD would be my mail order choice.
/ Air Compressor Fittings. #13
I have a large air system that goes to the house and various buildings. I have a small valve on every port to cut down on leakage. Not nice having to air up the whole (empty) system because you need a bit of air.
/ Air Compressor Fittings. #14
Same, only it's a box of old fittings instead of a can & I went with V instead of M. The Milton Vs flow better. Milton's seem to last longer & be better average quality than most. Not to expensive either although the are a fair bit more than Harbor Freight type stuff.
A few tools & hoses havent been converted yet, nor has my new Vair 400 12v compressor. I made some adapters to go from whatever fittings they are to the Vs just so I can stick with 1 standard. Even if I dont need the high flow on those tools or what not.
A Quick Guide to Air Line Couplers and Plugs
Cub Cadet Ultima ZT1 (A64557)
Cub Cadet Ultima...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
725 Gal Poly Tank on Skid  (A62679)
725 Gal Poly Tank...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
