Air Compressor Fittings.
   / Air Compressor Fittings. #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have two different npt 1/4 inch fittings for my air compressor. But they don't seem to be interchangeable. The one with a thicker collar needs to be forced a little more. What is the different name of these two fittings? Since I am in quarantine, I need to buy them online. 20200427_140432.jpg
   / Air Compressor Fittings. #2
Qual;ity Control?
I have never seen fittings that similar, if they are supposed to be different. What do YOU think they are?
   / Air Compressor Fittings. #4
I know for a fact there are a few different types of air hose fittings, and you have to buy the matching one's to fit. apparently, there's no standard for some odd reason!.. BTW, forcing it in is not good!. look here for a few types. McMaster-Carr
   / Air Compressor Fittings. #5
I only use Milton and get them thru home depot price seems to be the best around...
   / Air Compressor Fittings. #7
The one on the right is an I/M fitting which is the most universal. Not sure what the other one is
Just buy new I/M fittings and toss the other style. Fittings are cheap
Edit: I/M stands for Industrial/M. It’s Milton industries “Industrial” fitting and is the most commonly used in the USA
   / Air Compressor Fittings. #8
I have hundreds of "M" fittings that I decommisioned. I never saw different styles or had issues with connection. BUT, I changed to "A" I think. Don't know, got them all out of one Shut Down Manufacturing facility and it's the one all the Industry around here uses. I switched, because I much preffered the one handed connect feature.
   / Air Compressor Fittings. #9
You can get the M style one handed also .........
   / Air Compressor Fittings. #10
I hear you there Timberxx. I have five different "tools" for my compressor. Air nozzles, tire chucks, etc. I took the fitting that fit best into Spokane to the House of Hose. They specialize in all things - air compressor. They matched with four new fittings. Success.........
No doubt - this is one area where there is no such thing as standardization. All five of my tools had a different end connector fitting.
2015 FORD F-250 SUPER DUTY (A53843)
2015 FORD F-250...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
Cummins 7.5HDKAT 7.5kVA Portable Diesel Generator (A51691)
Cummins 7.5HDKAT...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
