Air bubble
/ Air bubble #1
blackpowder
Serviced my 06 L39 this weekend and noticed air bubbles in the hydraulic fluid. Does this indicate a problem?
Thanks from sunny Southern Utah.
/ Air bubble #2
Could be that you have air in the system that needs to be worked out. Remember to keep the oil topped off as the air is expelled.
/ Air bubble
I should have been more clear. The bubbles were in the fluid I drained out.
/ Air bubble #4
milky foam generally means water ...air bubbles would float to top and disappear quickly (like Champagne)...if the bubbles remain in suspension they sound like fluid and, if water, they might consolidate into larger bubbles.
/ Air bubble #5
It still could be that the oil level was low and air was mixed in. is there bubbles in oil now?
/ Air bubble #6
Was the fluid clear or milky? water will make it look milky.
Not sure where you are, If is was pretty cold the oil could be kinda think more like honey... and hold the Air bubbles in suspension for a short time
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
Water Pump with Engine (A65640)
Water Pump with...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
8ft 3in Teakwood Live Edge Slab Table (A65583)
8ft 3in Teakwood...
