Air bubble
/ Air bubble #1
blackpowder
Serviced my 06 L39 this weekend and noticed air bubbles in the hydraulic fluid. Does this indicate a problem?
Thanks from sunny Southern Utah.
/ Air bubble #2
Could be that you have air in the system that needs to be worked out. Remember to keep the oil topped off as the air is expelled.
/ Air bubble
I should have been more clear. The bubbles were in the fluid I drained out.
/ Air bubble #4
milky foam generally means water ...air bubbles would float to top and disappear quickly (like Champagne)...if the bubbles remain in suspension they sound like fluid and, if water, they might consolidate into larger bubbles.
/ Air bubble #5
It still could be that the oil level was low and air was mixed in. is there bubbles in oil now?
/ Air bubble #6
Was the fluid clear or milky? water will make it look milky.
Not sure where you are, If is was pretty cold the oil could be kinda think more like honey... and hold the Air bubbles in suspension for a short time
54in Wagon Wheel (A65583)
54in Wagon Wheel...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
INOP Kodiak Four-Wheeler (A65579)
INOP Kodiak...
2007 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2007 Allmand...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
