Air Bound
/ Air Bound #1
Anonymous Poster
Epic Contributor
YM1500. Changed fuel filter. filled bowl and filter.(overflowing as I tightened it)cranked. almost started. now it wont start.
Air Bound?
Where to bleed from and what's the procedure?
Thanks
/ Air Bound #2
There is a hex nut (about 12 mm) with a phillips drive, above the filter a few inches, as I remember. When I changed the filter in mine, I loosened that nut until fuel ran out. Then I tightened it and was able to start the tractor with no problem.
reb
/ Air Bound #3
Correction: It is a hex bolt head, not a nut. This #@?! computer isn't smart enough to print what I mean. /forums/images/graemlins/blush.gif
reb
/ Air Bound #5
There is a thread here somewhere that has really good instructions on bleeding the fuel system. Have you tried searching the forum? Do you have the manuals? It is in there too.It isn't too hard but the EPA would probably have a heart attack if they ever saw us doing it.
Chris /forums/images/graemlins/shocked.gif
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
John Deere 772CH (A64126)
John Deere 772CH...
2022 EZ-GO ELITE...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
