Ags or R4's in heavy timber country
   / Ags or R4's in heavy timber country #31
Here's a picture of a KAMA with real RICE tires on it. You can really tell the difference in lug depth.
Looks very cool.
   / Ags or R4's in heavy timber country #32
Looks very cool.
How does it ride on gravel or asphalt? Looks like you can swim with those fins! How do they compare to AG tires in use?
Bob
   / Ags or R4's in heavy timber country #33
Bob
This is what it says in the report I posted:Chosing the Right Tire
R2 tread is used in wet farming applications where the machine must run through mud and standing water. Typical applications are rice, sugar cane, and high-value vegetable crops. The tread is twice as deep as the standard R1 tread. While R2 looks extremely aggressive, the typical 45° bar angle is maximized for cleaning in wet soils and is not as efficient for developing traction as R1 in general farming conditions.
   / Ags or R4's in heavy timber country #34
Very nice looking tread. Looks like it can skim along the surface of a pond with enough speed!
Bob
   / Ags or R4's in heavy timber country #35
Bob
Mine does not those R-2's on it. What Mike posted is correct about those tires. I would guess if used in drier, harder or rocky surfaces, you could easily spin off one or more of those lugs? Where they would tear off the tire.
   / Ags or R4's in heavy timber country #36
Iowachild said:
What I am finding is that rice tires are R2.
QUOTE]
Right! My error. Sorry.
It's interesting to note that the tire in the pic above obviously has a 45 degree lug angle. Now look again at the tires on the KAMA. Those look to be about 25 degrees. I wonder who makes them?
   / Ags or R4's in heavy timber country #37
Maka said:
For our area and forrestry use R4's seem to be the preference.
Maka
In the report I posted, the only mention of forresty was in the part about tire construction. It stated that bias ply tire sidewalls were more resistant to punctures and the abuse in forrestry operations. I will have to start looking at the tires on timberjacks around here.
   / Ags or R4's in heavy timber country #38
I have R-4's and clay, I knew I would lose traction at times but in most places there is enough grass, weeds, branches, I have yet to be really stuck. The R-1's would tear up my next year lawn project considerably more than the R-4's do.
My theory, is get some tire chains if it is that bad, and if the chains aren't helping out enough it is a good day to work in the shop.
Great traction can be had, but the price is to tear up the ground, you must choose what is most important to you.
steve
   / Ags or R4's in heavy timber country #39
steve
You are soo right. My R1s cannot go near grass or the lawn will be destroyed. Especially if wet.
Bob
   / Ags or R4's in heavy timber country #40
Get R4's- much stronger sides then R1's. A small ( 6-10") stump will slice many sidewalls. I agree R4 are poor in heavy clay but are good overall. I run them on my tractor and it is set up for heavy woods use.
ROW tractors/logging equipment may have the tread pattern of a R1 tires but are 12-24 ply tires.
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pickup Truck (A59230)
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
