AGM battery?
/ AGM battery? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
I bought a "regular" wet battery about 1 1/2 years ago, for my Yamaha atv. I kept it inside and on on the maintainer, off and on. Went out to get going today, no cranking power. Put the jumper box on it and got it going. Battery is stone dead/bad, and won't take a charge. Being out of the 12 month warranty (of course), I'm getting another.
I ordered an AGM type this time and a new "smart" charger since I've read that the old/regular battery chargers can wreck the AGM batteries. True?
Are AGM batteries really that good?
/ AGM battery? #2
My opinion is sort of. When I was working as a land surveyor we used batteries to power or GPS base radio. It was very hard on batteries. The big advantage of them is for their size they were lighter and smaller. We ended up going to marine trolling motor batteries, they didn’t last as long and were heavier but cost a lot less. I also wonder if an AGM would hold up a little better in your application where it’s maybe in a rougher riding vehicle.
/ AGM battery?
Since the AGM was only a bit more $, I think it's worth a try.
/ AGM battery? #5
I got yellow AGM battery about 5 years ago and use it sometimes. But most of the time it's sitting in the garage. The problem is in about 2 weeks % charge goes to about 60%. Charge it on AGM charger and still does it. My other regular battery holds 100% for very long time. Not sure if all AGM like that or it's my luck))
/ AGM battery? #6
I like my Odyssey AGM batteries, and use them for most of my battery replacements.
I don't know what size your Yamaha uses. Is a regular size battery, or a tiny motorcycle battery?
/ AGM battery? #7
I also switched over to Odyssey batteries. I had several early demise and (2) catastrophic failures with Optima AGM batteries.
/ AGM battery? #8
I run one in my Jeep due to a high electrical demand (amps, winch, air compressor, lights, etc) and have had good luck with holding a charge and running all the accessories. The first one I put in died in about 2 months and gave me issues from the day it went it (acted like I had a small constant draw), but it was exchanged under warranty and the replacement has been great. The auto parts place said they almost never get an AMG battery brought in for warranty but if they do it is within the first several months.
/ AGM battery?
It's one of those small ones - 4x6"? The charger has the AGM mode, but I haven't rec'd it yet...
/ AGM battery? #10
agm are stock in atv's utv's etc due to vibration from the riding, standard battery's are more prone to failure in high vibration situations.
agms do have different charging requirements, but unless you have a old school wall wart charger, most standby chargers work fine
/ AGM battery? #11
I put an Odyssey AGM battery in the Kubota - six years ago. It cost $399. - six years ago. I do keep it on an AGM designated trickle charger. - during the winter.
It's the heaviest group 31 AGM battery I could find. 1150 CCA. At 78 pounds - it was a real bear to lift into position on the tractor.
/ AGM battery?
I have two chargers - each more than 25 years old, and two new standby maintainers. I thought a new 10a "smart" charger might be the "smart" thing to get...
/ AGM battery? #13
AGM batteries are better. And if the charging system in the vehicle is designed for AGM then it will output a higher voltage that AGM needs. If you use a regular old float battery you will probably ruin it (like you possibly did) due to that charging system design.
I used a NOCO Lithium battery on my snowmobile this year. Lighter and uses a specific NOCO charger as well with Lithium mode. Time will tell if it works well in the AGM application. So far this year it's been ok.
/ AGM battery? #14
I putthree AGM batteryin two trucks and a car in 2017. All three batteries are still going strong.
The two trucks were used for plowing. One also had a short somewhere that drained the battery probably four ot five times. Recharged it each time with a Noco Genius snd have never had an issue.
I think I paid about $270 for each one in 2017. Prior to that, I would have to replace my regular batteries every three years, so it has been worth it.
