Agco ST30X front axle disassembly
   / Agco ST30X front axle disassembly #1
fbagg
Fresno, Ca
John Deere 6430
Any clues on how to get the nut out? I have bent the depressed area, that is serving as a lock, back but there is no room for a wrench and the shaft is 6" long so there is no socket that will reach.
   / Agco ST30X front axle disassembly #2
I don't know if a parts diagram would help but AGCO Parts Books ( enter as Guest) has them.
You may have to make a tool. Might be an expensive sacrifice to what appears will take a large socket but you could cut the drive end off a socket so it fits over the shaft and weld a handle to it. If the socket is tall enough, you may be able to simply turn it with vice grips or pipe wrench and not have to weld a handle to it..
Thanks Darryl got the picture, and good idea on the socket, if no one comes up with anything better that's probably what I will have to do.
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 KUBOTA KX033-4 EXCAVATOR (A52707)
2020 KUBOTA...
