Again a 16x16 Ford NH transmission
   / Again a 16x16 Ford NH transmission #1
JULESB
St-Hyacinthe, Qc, Canada
Ford 6640 SLE
Hello from a new member.
I have a 1993 Ford 6640 SLE tractor (5 000 hours) with the famous 16x16 transmission. It's a 3 levers transmission with the nearest stick being a shutlte that has to be moved in forward or reverse to engage the transmission. Lately when I move the shuttle stick to select forward or reverse, no gear engaged. The tractor has been checked by 2 different NH dealers without any result. The only way I have found to keep moving the tractor is the following procedure : before shifting the shuttle stick, I quickly depress the foot throttle pedal to increase the motor RPM and as soon I release it, I smoothly shift the shuttle. I'ld really like to find another to keep my tractor moving!
Our comments will be appreciated.
   / Again a 16x16 Ford NH transmission #2
Try asking this question in the New Holland Forum. There are a couple of NH techs that post thre ad they may be able to help.
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
