Again a 16x16 Ford NH transmission
   / Again a 16x16 Ford NH transmission #1
JULESB
St-Hyacinthe, Qc, Canada
Ford 6640 SLE
Hello from a new member.
I have a 1993 Ford 6640 SLE tractor (5 000 hours) with the famous 16x16 transmission. It's a 3 levers transmission with the nearest stick being a shutlte that has to be moved in forward or reverse to engage the transmission. Lately when I move the shuttle stick to select forward or reverse, no gear engaged. The tractor has been checked by 2 different NH dealers without any result. The only way I have found to keep moving the tractor is the following procedure : before shifting the shuttle stick, I quickly depress the foot throttle pedal to increase the motor RPM and as soon I release it, I smoothly shift the shuttle. I'ld really like to find another to keep my tractor moving!
Our comments will be appreciated.
   / Again a 16x16 Ford NH transmission #2
Try asking this question in the New Holland Forum. There are a couple of NH techs that post thre ad they may be able to help.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
John Deere HPX615E Gator 4x4 Utility Cart (A51691)
John Deere HPX615E...
59in Tooth Bucket (A51573)
59in Tooth Bucket...
