Ag Tires versus Industrial tires
   / Ag Tires versus Industrial tires #71
Those punji stakes left after mowing are really scary! I haven't yet punctured a tire, but I've lost a valve stem and run the fronts off the rim a couple of times in brush. The last time this happened, I drove my lawn tractor with dump cart back into the woods to retrieve the wheel/tire and bring it back home for repair. It would have been a whole different issue if it had been a rear tire!
I lowered my air pressure in my R4s to 12 psi front and rear. It helped a little, but they are still pathetic on the ice and snow.
   / Ag Tires versus Industrial tires #73
No problem at all. :) I know what you mean. Nothing but bad breaks.
The reason I asked is that I use AGs and have had only a few punctures - mostly from pointed stobs from 1.5 to 2" dia stumps left by beaver. :eek: You dont plug those! In only one case have I gotten punched by small wood. In that case, like yours it was a seasoned pungi from a prior cutting. All in all Im pretty impressed with the puncture resistance. It surprised me that an R4 carcass would be vulnerable to small wood.​
... One thing Ive noticed is that new tires cut and punch more easily. I think the rubber is soft for quite awhile and a middle aged tire is probably at its very best for resisting penetration. Its tougher all the way through. Im betting those R4s are kinda young ? Theyll be stronger in a few years if they dont get perforated too much before then. ;)
The R4's are new. This area I cut in May first attempt with my 4610 and after 2 front flats and repairs I came home and got the Workmaster with the R4's. Got along fine. I figured I would be OK this time also but it didn't work out as I planned. It does build character. Lol
   / Ag Tires versus Industrial tires #74
I run 2 link v bars on my Kubota l3400 with r-4 and it's a big improvement with just the front axle chained up.
   / Ag Tires versus Industrial tires #75
Also, r4's offer no resistance to sliding sideways on greasy ground while ag's or even turfs offer some grip.
   / Ag Tires versus Industrial tires #76
What's the reasoning behind this statement?
   / Ag Tires versus Industrial tires #77
Big fat lugs with no tread. At least with a AG one tread is angled the opposing direction when sliding sideways. The tread blocks are not as wide and flat either.
   / Ag Tires versus Industrial tires #78
And the turfs are better? I've got r4s on my tractor and I wouldn't consider anything else.
   / Ag Tires versus Industrial tires #79
It's the same reason big lugged mud tires on a truck is horrible on ice or packed snow. Winter tires have lots of grooves and sipes. I ran identical tractors on two farms, one had turfs and one had r4's. I now only have the one with turfs. :)
   / Ag Tires versus Industrial tires #80
Turfs definitely have better traction on snow, but I thought this was an on dirt comparison.
18024 (A49346)
18024 (A49346)
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A50397)
2018 Rock Solid...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50046)
2017 FREIGHTLINER...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A50397)
NEW 2022 Load...
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A48836)
2000 Volvo VNL...
