Ag Tires versus Industrial tires
   / Ag Tires versus Industrial tires #91
Have you considered pickup swamp mud tires? May be a size that fits.
One of the problems with truck tires would be too many plies. The 12x16.5 tire size is a Skid Steer size to fit a 9.25x16.5 6 bolt wheel. Truck tires on that sized wheel are also built for heavy duty service. Skid steer tires run 10-12 plies. The OEM tires on my 2400 were Tiron F4s (Korea with Korean built tractor) but were only 6 plies. No where else on the www did I find that size with that few plies.
My problem is a tractor that weighs 1850#, plus 400 (guess) is FEL, so figure 1000# (for a number) on the rears + me for say 1250/2 =625# actual load per tire and it comes with tires on the rear rated at 2300+ # per tire x 2 = 4700ish # buoyancy at rated 30 psig.....Even down at 7 psig it's hang on for dear life.
The turfs will work for me at the 7 # current pressure. With the 4 plies and larger volume of sidewall I have more to absorb the "bump" pressure transient. I was just curious and had it answered in that there weren't any F1s out there if somebody wanted to plow with this sized machine. So I guess one would have to use a rototiller which is ok for a garden or small acreage with their R4s or R3s.
   / Ag Tires versus Industrial tires #92
I have found, generally, that wider tires ride MUCH nicer,,, if both tires have the same # of plies.
is there any chance you could find wider tires?
(if you look hard enough,, you can find cheap wheels)
2023 Chevrolet Tahoe SUV (A48082)
2023 Chevrolet...
(2) SHORT BOLSTERS (A48992)
(2) SHORT BOLSTERS...
Bin Wagon (A49251)
Bin Wagon (A49251)
QA Sander/Spreader Part (A49251)
QA Sander/Spreader...
Howse 3pt 5ft Bush Hog (A49251)
Howse 3pt 5ft Bush...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
