Ag Lime Spreader?
/ Ag Lime Spreader?
My dad says he has an old Deere grain drill with all the blades and crap removed that they used to use as basically a drop seeder. It’s almost identical to this one, but smaller. Do you think it would work for ag lime?
/ Ag Lime Spreader? #22
This sounds like a very good system. I called and spoke to the owner a year or so ago. I'd like to have one, but for the quantity of lime I spread, it's more economical to use pelletized.
Lime Spreader - Sides Spread-all Spreaders
/ Ag Lime Spreader? #23
You might as well invest in the smallest Vicon pendulum spreader for your ag lime as it will handle it.
The problem would be dumping the lime near your food plot and hauling it to where you need it and
then shoveling it into the spreader.
Short of renting a dump trailer to haul the bulk lime to each food plot and then shoveling it into the spreader
each time I do not see another option.
I never had an issue with handling bagged ag lime other than making sure I wore a mask when dumping the bags.
/ Ag Lime Spreader?
There’s a parking area at the entrance to my property that I could have a dump truck dump the lime. I have a loader on my tractor that I can scoop and fill a spreader with.
/ Ag Lime Spreader? #25
that should work if the agitator is still in it . If not drive it like you stole it and let the rough terrain do it
/ Ag Lime Spreader? #26
I'm not sure how close you are to Clinton, MO, but check this out. TractorHouse.com | JOHN DEERE 65 For Sale
I'm sure it may need some repairs of some sort, but overall, doesn't look too bad. I have a similar spreader that was made by United Farm Tools, that I bought 20 years ago. Wasn't in the best of shape then, but kept patching, until a rebuild was needed. Did that last winter in the shop for something to do. If it lasts another 20 before needing anything else, it will be someone else's problem.
/ Ag Lime Spreader? #27
Looking at the pictures below the main on, the one shows 2, pto shafts separated at right angles. I'm assuming the one goes back to the spinner, and the other is from the ground drive, for the apron chain. I went to the JD online parts catalog, but not really seeing what is missing. http://jdpc.deere.com/jdpc/pdfs/PC1266.pdf
Still might be worth calling, and see if they know what needs to be repaired. It is listed at $1500.00, but, also says, "Make an offer."
/ Ag Lime Spreader? #28
I'm telling you friend...the best scenario for small plots of land in terms of convenience, cost, and get the same or better result is pelletized lime.
You confusion might come from not truly understanding the difference in the RNV of pelletized vs ag lime. The efficacy of the product comes from the RNV%. Pelletized lime RNV (relative neutralizing value - which means neutralizing the acidity of your soil) is higher than ag lime. Example, your local quarry will tell you the neutralizing value of their lime, mine is 50%. Pelletized lime is usually pushing 97% give or take a few % points. SO, 2000# of ag lime contain with a 50% RNV value will equal 1/2 ton of pelletized lime.
Having ag lime hauled to your property and dumped and then you having to use your loader and load into a spreader, then hoolk up the spreader, spread your material, then unhook and load from your pile is quite the chore as compared to just having it mixed in with your fertilizer you are spreading for your plots. The haul bill adds cost as well.
Been there and done all this. For small food plots, the crop production supplier of bulk fertilizer and pelletized lime is the way to go. All the commercial tobocco guys are going this way.
/ Ag Lime Spreader? #29
Local Extension Agent told a buddy of mine, pelletized lime, commonly known around here as quick lime, is pretty much good for one year. Where as Ag lime will last approx. 5 years. It will reach it's peak at neutralizing @ between 2-3 years. When I questioned the agent about it, he told be to apply the suggested rate, then in 3 years, apply it at half the rate, and it should be near the suggested amount to keep it at that level.
/ Ag Lime Spreader? #30
That is a myth.
/ Ag Lime Spreader? #31
That's a tough situation-I'm in the same boat. Have planting several acres of food plots-mostly irregular shapes and small-no feed store is interested in spreading it.
I have used some pell lime. I buy 40-50 bags when it goes on sale and spread it through my broadcast spreader. I can apply all the lime I need at once but keep rotating through my plots, slowly increasing my ph.
I think I may get a couple of friends to help out this spring and buy a few tons ofAG lime and spread with shovels out of my loader bucket or the back of my RTV. I have done a ton before by myself-a bit of exercise but not unbearable.
Will
/ Ag Lime Spreader? #32
I知 in search of some kind of implement that I can use to spread ag lime on my food plots. I need to spread about 6-7 tons of ag lime. Pelletized lime is going to be ridiculously expensive for the amount I need. There are absolutely NO places that rent lime buggies within an hour drive of me. There is one guy that uses a spreader truck, but he can稚 fit it through the trails on my property. So I need to figure something out that I can use to spread the lime myself.
I have a tractor and loader, but I can稚 seem to find anything that痴 not crazy expensive to use to spread the lime. My grandpa said you could spread ag lime using a small seed drill, but I can稚 find anything online to support that. Seems like it would need some kind of agitator to keep it flowing.
Any advice?
Something like our Kent would probably work, also branded as Co-OP worked well for spreading pellatized lime
I am not sure how it wooould do with the ag lime.
Just a thought if you find something similar.
/ Ag Lime Spreader? #33
OldRed is correct.
/ Ag Lime Spreader? #34
The guy I bought my Herd 750 sand spreader from used it to put down Ag lime on a small field. But years of neglect leaving both lime and fertilizer in it rotted it to the point where I had to rebuild it. It has an agitator in side it that beats the sides as it spins. I don't know how well it worked, just that he did use it. I suspect that the fertilizer did in the bare steel and the lime corroded the aluminum plate at the bottom of the hopper and the spinning wheel that throws it. What ever you get make sure to keep it clean.
/ Ag Lime Spreader? #35
This might be completely crazy but what about some type of sandblaster??? Depending on how big your plots are
/ Ag Lime Spreader? #36
That won't work but it my younger and more foolish days I once put down 3/4 acre of lime with a drop type yard spreader. It wasn't that bad, didn't take that long and was great cardio. If I was young and broke and the grass was pretty short, I could see being able to put down two or three acres. I've done harder things to get ahead in life. Even today I would do that 3/4 acre again if I had to. :)
/ Ag Lime Spreader? #37
I say Pelletized lime as well... been there done that.
As far as application rates and how often for either... your soil make up will define that. For instance we have sandy soil here... doesn't matter what I put down, it leaches out quickly.
Pelletized unless your doing huge ag style fields, but your not so save yourself the headache your creating.
