aftermarket cabs anybody make a plastic one?
   / aftermarket cabs anybody make a plastic one? #1
dan8152
Burlington wi
Kubota L2501 hst, belarus 825
Ok looked at curtis and also sims for my kubota.
they look like budget products for a premium price!!
got me thinking I see those nice plastic sheds at the big box stores or even those plastic deer stands that are enclosed. Most even have windows. does any company offer a cab out of plastic? I just need the wind/ snow off of me and those sheds snap together and are quite durable. A company could make a killing selling a $1500 hard plastic cab that snaps together for winter seasonal use.
If my only option are those two above brands I would rather sell my tractor and put the 5K to a factory cab.
anyone in the plastics business? this type of plastic could make a great cab!
   / aftermarket cabs anybody make a plastic one? #2
Since it has to be custom designed for each tractor model and the market is limited, don't expect to see bargain prices on cabs. The best "bang for the buck" is a soft cab like Original Tractor Cab - about $1000.
   / aftermarket cabs anybody make a plastic one? #3
Back in 1973/74 I worked at a place that made tractor cabs but back then I suspect the number of different tractors was quite a bit less than today.
   / aftermarket cabs anybody make a plastic one? #4
I put a Sims cab on my B2910 years ago. Poor quality control and horrible customer service. I finally got a new B2650 w/cab, and couldn't be happier.
   / aftermarket cabs anybody make a plastic one? #5
Been told plastic side panels create significant optical distortion. Same issue if front panel is NOT glass. I added a glass cab for two reasons.
First, have tractor I like
Two, it is tier 3, no DPF, other emissions devices.
Three, tractor has low hours, 230, and purchased new with super dealer discount, new mx 5100, hydro, rear lite, remote, $20k. (+tax)
So $ 4k for a cab was logical choice. Added new kubota loader, SSQA , grill guard, self installation, $4800. Including $470 freight. (No tax)
Price a mx 5200, w/ loader today, obviouly no cab, and what is your total?? See what I mean?
   / aftermarket cabs anybody make a plastic one? #6
got me thinking I see those nice plastic sheds at the big box stores or even those plastic deer stands that are enclosed. Most even have windows. does any company offer a cab out of plastic? I just need the wind/ snow off of me and those sheds snap together and are quite durable. A company could make a killing selling a $1500 hard plastic cab that snaps together for winter seasonal use...
View attachment 545190View attachment 545191
Great idea! Start with most popular models.
   / aftermarket cabs anybody make a plastic one? #7
Purchased an Original Tractor Cab for my Kubota B2320. Cost $900+. Well worth the money. Wished I had done it sooner. A lot more comfortable plowing the drive way!
   / aftermarket cabs anybody make a plastic one? #8
If I was going to build a cab, I'd use 1/2" or 3/4" square tubing to build the frame. Then the same to build door and window frames. Make sure it all works right, opens and closes, doesn't hit joystick at full extension, 3pt top link doesn't crush it, etc....
When it all looks good, I'd then fill it in with foam core sheets, then fiberglass and gel coat. For windows, I'm not sure. I had a cab with glass. After years in the woods, every single pane had a crack, but was still clear. I'd probably go with glass for the front, and plexiglass or lexan for the sides. I'd definately make the doors removable for summer, as I have no way to air condition.
   / aftermarket cabs anybody make a plastic one? #9
My father had an old Curtis; Glass windshield with wipers, glass top, and removable vinyl sides and back. He used to put it on in fall and take it off in spring. It had no heat except that from the engine, he would leave the side windows down for visibility and dress in his snowmobile suit.
He stopped using that tractor about 20 years ago, but the cab is still in the barn and I might steal it. I may even take the tractor, a 56 HP gas Ford 4400.
   / aftermarket cabs anybody make a plastic one? #10
I had one from Bercomac for a few years until built a winter cab.
4" Soft Cab for Compact and Sub-Compact Tractors
Was not the greatest, still let in some snow and wind around the bottom but it was alot better than nothing
Here are some pictures of the cab I built out of wood and plexiglass:
   / aftermarket cabs anybody make a plastic one? #11
   / aftermarket cabs anybody make a plastic one? #12
Excellent job! I’ve been trying to figure out a way to make one for my Kubota GR2120. I want something that’s easily removable.
I’m thinking of fabbing-up a base first that is molded to fit on the tractor, then I will build the shell once I got hat figured out. The GR2120 is very curvy, so it will likely be a bit of a challenge.
   / aftermarket cabs anybody make a plastic one? #13
don't know if they still sell it or not but wiedmann bros used to sell a drape over enclosure. All you needed was a canopy and then their enclosure just draped over the sides, no fuss install for sure but was just a vinyl enclosure nothing special and since it just hung there was no vertical supports.
   / aftermarket cabs anybody make a plastic one? #14
They do, its the same price for their zipper enclosure as for the Original Tractor Cab which has swinging doors ($1300-1500ish).
Aaron Z
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2008 New Holland T2420 (A60462)
2008 New Holland...
