Affordable chain?
/ Affordable chain? #1
Watercarving
Kubota b2920
So after all the advice on chains I decided on 5/16 grade 70 or 3/8 grade 43. Went to Tractor Supply and it was $65 for 20' with hooks or $3.79 per foot for raw chain. I wasn't expecting that much. Is there a better place to buy or is that a good price.
Also, they didn't have any grab links or Clevis pins as big as I needed. Seemed strange.
Thanks.
/ Affordable chain? #2
Tractor Supply is kind of a on the expensive side in my opinion. Here is another source you could use.
Grade 70 Chain -
/ Affordable chain? #3
Lowes has had a decent price on a pack of grade 70 chain in the past. I got a couple there, and am happy with them, though I needed to put different ends on for a couple special setups.
/ Affordable chain? #4
Lowes has pretty good prices on chain,and harbor freight is having a sale now.32.99 for 20 ft 5/16 grade 70 or 24.99 for 14ft grade 43.
/ Affordable chain? #8
One of the things with chain is that the shipping charges can be very high. However, I did notice that Harbor Freight is running a $7 shipping for everything through 12/31.
I usually get my tie downs and chain from A-W Direct. Quality and good service but probably not cheap. But they have anything you need for towing and tie downs.
Ken
/ Affordable chain? #9
One thing to think about... 5/16" chain will be heavy. I would recommend getting a high quality small diameter chain. I have one and it has never broken and I have used it for a lot.
It is light and easy to move.
I use it for pulling stumps, moving stuff, pulling stuff, lifting stuff. It has one hook on each end.
/ Affordable chain? #10
Here is the Lowes chain, $38 Made in USA. I have 1 from Lowes and 1 from HF. The HF chain has lots of weld flash on the links and oversized 3/8" hooks which can be harder to thread and add stress to the hooked link. I would say the Lowes chain is worth the few extra $ on quality alone, Made in USA is a bonus.
Shop Campbell Commercial 5/16" x 20' Tow Hook Chain at Lowes.com
/ Affordable chain?
Had $50 HD card. HD had the 5/16" 20 ft. Grade 70 for $38. Got two and used Christmas money to boot!
/ Affordable chain? #12
tagging onto this thread, does anyone know of good prices for grade 70 1/2 inch chain?
/ Affordable chain? #14
If you can find a military surplus store in your area you might check there. I found some 1/4 inch that was rated at 5000 lbs. It is lighter weight like the others stated, the only down side is it has the bent hooks like all military chain and was only 10' in length. I took a 10' cut it in half and connected it to a whole piece which made 15' and these work great as tie down chains. Like all military stuff it is good I am sure I have had it over its rating because it will stand all a 3500 4wd truck will pull.
/ Affordable chain? #15
Harbor Freight has the 5/16 G70 20' with two grab hooks for $20 on sale starting 1/1/12. Here is a link to the coupon http://images.harborfreight.com/hftusa/itc/7851/images/147.jpg Although the coupon is for the Inside track club most just take the coupon and don't ask for a membership card. I have bought several of these chains and they are great.
/ Affordable chain? #16
Twenty feet of chain is a lot for one tie down. I had two of the Loew's twenty foot chains cut in half and ends added for not too much. Find a place that sells wire rope. I could have had one cut into four and still had enough to tie my tractor down, it would have been neater too.
/ Affordable chain? #17
I have used the Harbor Freight chain with no complaints.
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
UNUSED SWICT 78" BUCKET (A64280)
UNUSED SWICT 78"...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2005 Stertil Koni...
