Aerator for BX
/ Aerator for BX #1
teachdocs
Kansas City, KS
Kubota BX23
I am considering the Aeravator with seedhopper from FirstProducts. They have a 40 inch pull behind PTO driven unit. Anyone with experience on these devices?
Here are two links for the unit I am looking at:
Aeravator specs
Aeravator overview
Will it fit a BX23 and have sufficient lift capacity from the 3PTH? The specs show it will weigh over 800 pounds loaded with seed (24 in. Behind Lift Point). That seems to be pretty close to capacity of my BX from what I can determine.
Thanks for the advice. I have learned a lot from this Forum and have found it very helpful.
/ Aerator for BX #2
One of the pictures on their website shows the aerator (without the seed hopper) hooked up to what I believe is a Kubota B6000. You might try looking up the 3pt specs on the B6000 to see what it's lift rating is and then compare those to the BX.
Maybe the aerator Co. has an idea of what type of tractor will handle the aerator also. They might have somebody out there who already uses one on a BX.
If you don't mind me asking - what is the going price for one of these? and why did you choose this Mfr. and model? I ask because I may be in the market for an aerator down the road and have been trying to keep up with all the choices out there.
/ Aerator for BX #3
I'm sure you have your reasons for the purchase of that unit but have you considered a 3pt hitch core aerator and a good drop seeder. If that thing uses spike type aeration that just compacts the soil. Just my thoughts.
/ Aerator for BX
Thanks for the advice to look up specs for the B6000. Will see what I can find.
I "hear" the retail price for one of these is about 4K. "ouch" I was looking for a product that will not leave cores on the yard, disturb the surface turf the least, and provide for variable subsoil fracture depending on PTO speed. In addition, this is the only unit I have found that is small enough in weight for my BX but also provides a central pivot to the 3PTH to allow usage around turns.
My experience with tractor size aerators in the past is that they had to be huge and heavy to be effective, and would tear up more than they helped if you did not travel in a straightline direction without lifting the implement first.
The small pull-type core aerators are lucky to penetrate more than an inch or so into the soil and do not have seedhopper attachments.
Anyone have any other suggestions?
/ Aerator for BX #5
check out the Jacobsen 548-100 seeder, weighs 400 pounds. might work for you.
/ Aerator for BX #6
I have a Woods 48" core aerator that I use with my BX2200. It is their PL 48 & weighs 320 lbs. I add 400 lbs. of weight to it.
3 years ago, I bought it, but unsure of the price right now.
I reccomend that you use a 3 point hitch type, unless you have plenty of room to turn it around. The 3 pt. type allows you to back into tight areas that you won't reach with the pull type.
You will also need to have front counter weights to balance the aerator, or you'll be pulling wheelies when you lift it.
Besides the price, you'll probably need a larger machine to use a seeder/aerator unit, as they are heavy for the BX series.
I have also found that soil type & moisture determine your depth of penetration, along with the weight you can put directly over the core pluggers. In damp topsoil, I have removed 3" cores with my set-up, in dry clay sometimes 1-1.5".
I hope this info is of use to you.
WALT
/ Aerator for BX
Thanks a lot for the additional ideas on aerators.!
Hopefully, one of these options will do the job for less money. /forums/images/graemlins/grin.gif
Any recommendations on a good 3 point fertilizer spreader for the BX?
Chad
/ Aerator for BX #8
I have a Landpride FS-500 spreader which I use for sanding my driveway. I believe that it has either 350 or 500 lb. material capacity. If you have a Tractor Supply Co. store near you, the same spreader is sold, but painted red. It appears that an Italian Mfg. makes them for numerous US vendors.
I paid $500.00 for mine last year from my Kubota dealer, TSC has the red model cheaper.
I did have to shorten the PTO shaft to use it on the BX. I also reversed the lift pins to the inside.
I'll attach some pictures, as it stays on the BX all winter.
/ Aerator for BX #9
Picture #2
For sanding the driveway, I made up a wood "shutter" to control the spread width of the sand. Prior to using this, I was sanding the woods more than the driveway. It is adjustable, and as set up spreads the sand in a 10'-12' pattern.
The bottom piece is the castered dolly that holds the spreader when off the tractor.
WALT
/ Aerator for BX
I just purchased a similar spreader from TSC. The 500 lb capacity model.
I have a question about the PTO shaft: If you install the unit according to instruction manual, you are supposed to set the spinner plate approximately 80cm off the ground (the rear tires and lift capacity will not go that far). The spreader will fit with the 3PTH fully raised, but creates a problem with PTO shaft length.
In order to have the necessary 2 inch PTO sleave clearance when raised, you will pull apart the PTO assembly when the unit is lowered to the ground as the PTO shaft extends.
What did you do with your unit?
My current compromise is to raise the unit to where the PTO shaft is level with the PTO takeoff. This is several inches below maximum lift. At this point, I have about 1 inch of clearance in the PTO as it's short length. When you drop the spreader to touch the ground, the PTO remains assembled, but barely....just enough to raise it again.
Would adding length to the 3PTH trailing arms make a difference? Such as adding a quick change type of device?
Any way to limit how far the 3PTH raises for this setup?
/ Aerator for BX #11
teachdocs, the Aeravator 40L is a phenomenal unit. You have plenty of tractor with the BX to operate it. Just make sure that you have your FEL attached. If the steering feels light pick up a small amount of dirt. I operate the Aeravator 40L with a JD 2210. I do not have the seed box but would like to get one.
/ Aerator for BX #12
You might want to look at the Fergeson Yardmaker if you are not looking at a core aerator. I use one for over seeding and fertilizing on a BX 22. You will have to lift it on turns. You can add sand or water to the drum for weight. It is in the $1500.00 range. Sweet Farms a KY dealer listed on TBN carries them and will ship. Check his sight out and he probably has them.
/ Aerator for BX #13
That looks like one sweet aerator, but I like the simplicity of the Midwest 60" aerators. Build extremely well and nicely finished..
/ Aerator for BX #14
I spent many hours using a 40" Aeravator behind a BX2200. Worked great. Best aerator I ever used.
/ Aerator for BX #15
Anyone have feedback on the Leinback aerator? I like the design and the water fill idea...thoughts?
Thanx,
Curt
/ Aerator for BX #16
Hi all-
I've been following the aerator discussion with interest. I have 5 acres total, about 1.5-2 that I'd consider "lawn" and the other 3-3.5 that gets mowed roughly every third time I do the lawn. I have a BX2230, btw.
I'd like to aerate the "lawn" area about 2x per year (spring/fall) and the other part 1x per year. Time is not a huge consideration - seat time is how I relax and think. The only other possible use of the unit would be by my neighbor who has roughly the same situation.
I have a few rocks around, but tend find and dig up most of them before stuff hits them. The way the property is laid out means that I can pretty much design my route to avoid crossing the driveway and any walkways.
I'm able to afford one of the larger units I've seen, but I have to confess that spending more than the price of a box blade for something that I won't use more than 2x per year seems a bit much.
Is this unit from Sears too light for the work I describe?
Craftsman 24328 42 in. Plug Type Aerator at Sears.com
Thanks in advance.
/ Aerator for BX #17
Having had the exact same Craftsman, I would think not. Mine died doing an acre lot a few times a year. The extra weight on it just killed it and the quality of materials and construction just wasnt enough. I eventually went to a Midwest and its been used on MILES of trails and its still working perfect.
/ Aerator for BX #18
WALT
More upgrades during some spare time in the shop, for my Woods PL-48 aerator. In the past, my added weights were loosely strapped down on top of the aerator. That allowed for them to shift and move, not good @ 100 lbs apiece.
I had some 3" angle from a past job to fabricate a weight bracket, holding the weights securely, especially when transporting on the trailer.
I added a piece of 2" angle to hold the weights forward.
I had the steel & paint already, cost was limited to my time.
2 hours cutting, grinding & welding to complete the project.
The 4- 100 lb. weights lift out to use on my rake & boxscaper, secured with a 1" ratchet strap.
WALT
2000 Hino (A64194)
2000 Hino (A64194)
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
