Advise please:: Rear Halfshaft removal and brakes - Iseki tractor model TX2140
   / Advise please:: Rear Halfshaft removal and brakes - Iseki tractor model TX2140 #1
Marcle
Herefordshire/Gloucestershire boarders UK
Iseki 2140
You may have seen my other post wanting a rear halfshaft or two and one has snapped, so the other may be on its way out.
I suspect I'll work it out one I start getting my fingers dirty, but a heads up will be helpful please. Most halfshafts I've worked on, are held in place with a collar behind the main bearing which is pressed on to the halfshaft, however this looks a bit different. In the image below, I can see a circlip holding the bearing in place, is that all that hold the shaft in place, assuming the bearing was a friction fit? Or do I need to remove the housing secured with the green arrows?
Secondly, are the brake shoes behind the housing with the red arrows? I'm assuming they're dry shoes, rather than wet?
Thanks in advance. :) Sam_38255.jpg
   / Advise please:: Rear Halfshaft removal and brakes - Iseki tractor model TX2140 #2
Here is some info/pictures.
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
1268 (A50490)
1268 (A50490)
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51246)
2017 KOMATSU...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
