Advice on wheel weight brackets?
/ Advice on wheel weight brackets? #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Hi Folks:
I'm thinking of making some sort of bracket to hold barbell type weights on the rear wheels. I'm thinking a simple triangular shaped plate plate with a bar sticking out perpendicular to hang the weights on would be ideal. A couple or three 50-lb weights on each side ought to be good. The price is attractive, they're about $0.20-0.30 per pound (cheaper if you buy them from a person rather than a used fitness goods store).
One question: my rear wheels have six mounting bolts. Would it be better to make the triangular plate such that I take 3 of the bolts out, put the plate on, then put the bolts back in? In this case, the bolts holding the rim to the hub would be maybe a 1/4" or maybe a little more short of the depth they had before. It looks like there's an 1/8" thick washer between the wheel lugs and the rim now, so I could remove that.
OR, would it be a better idea to just drill 3 holes into the rim and mount the triangular plate that way? I would drill outside of where the hub is, but not to where it does into area of the wheel that holds pressurized air, of course. I doubt three 1/2" or so holes would substantially weaken the rim, right?
Dave
/ Advice on wheel weight brackets? #2
Dave if it were me I would opt for removing the washers and installing the triangular shaped support. Not keen on drilling any extra holes in any rim. Just be sure that you re-torque the wheel bolts after you reinstall them per your operators manual and I think you'll be good to go.
/ Advice on wheel weight brackets? #3
Dave,
Doesn't the MF 1220 have any accessory holes in the wheels?
</font><font color="blue" class="small">( Dave,
Doesn't the MF 1220 have any accessory holes in the wheels? )</font>
Nope...no accessory holes, just the 6 bolt holes for attaching the wheel to the hub.
Dave
/ Advice on wheel weight brackets? #5
Does the wheel have flat pressed areas on the disc?
</font><font color="blueclass=small">( Does the wheel have flat pressed areas on the disc? )</font>
I had to go look. Actually, no. Looks like the wheel is just the cylindrical piece that the tire seats on with a flat round plate welded into the middle of it, in a nutshell. It appears to be a single flat plate without looking too close. Seems like it ought to be alright to just drill 3 or 4 holes in it....
Dave
/ Advice on wheel weight brackets? #7
I was hoping that there was some flats for you to drill. I don't think that you would hurt anything by drilling your own holes.
/ Advice on wheel weight brackets? #8
My old fords have lots of extra holes drilled for weights.. no rim failures yet!
Soundguy
2005 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2005 BIG TEX 16...
1998 International 9400 (A64127)
1998 International...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2018 Genie GTH-5519 (A64126)
2018 Genie...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
