advice on tiny hydraulic dump trailer?
/ advice on tiny hydraulic dump trailer? #1
oldboyscout
ne PA
Kubota B2620
I have a bunch of utility trailers. a 5x10 for building materials, firewood, moving kids to college etc. The other is 4x6 that I use around the property for firewood mostly because it's small enough to manouever around the woods.
I'm looking at the Sure Trac 4.5 x 8 dump to replace both those trailers. ( Sure Trac | ) It would be nice to be able to pick up a ton of gravel or soil myself. I'm worried that I may be disappointed with the small tires or some other feature. Also I will have to rig up some kind of stake sides to add enough volume to move things other than gravel.
Anyone have experience or advice for something like this?
thanks
/ advice on tiny hydraulic dump trailer? #2
I know someone that has used a similar trailer. It works well but like you said, isn't very heavy duty. I'm not sure it would haul even a ton of materials but you can probably tell by the weight rating. Used within its limits, I'd think it would do the job for you.
/ advice on tiny hydraulic dump trailer? #3
I would say get something a bit bigger if you want it to be useful to pick up material. The payload on that trailer is just above 1 ton and a yard of gravel is going to be more like 1 1/2 tons.
unfortunately that's about the limit for my tow vehicle anyway.
/ advice on tiny hydraulic dump trailer? #5
Sure Trac is just around the corner from me, and they do have some nice trailers.
Have you called and talked to them at all?
I called but they really didn't want to talk to me me. I was referred to the dealer for all my questions.
/ advice on tiny hydraulic dump trailer? #7
I picked up a used Cross Country Mfg. 5x8, dump from a local rental place. It has a 2 ton payload and after some TLC and paint I probably have less in it than those are new ($1,300 purchase and about $600 in parts, paint). Just a thought. I did look over something equivalent to those sure tracs at the dealer where I purchased my Massey from and was not super impressed.
2016 JOHN DEERE 300G LC EXCAVATOR (A65053)
2016 JOHN DEERE...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
2022 Kubota SVL97-2 Compact Track Loader Skid Steer (A64553)
2022 Kubota...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
