Advice on purchasing a zero-turn
/ Advice on purchasing a zero-turn #1
Nissan197
Platinum Member
Kansas
Mahindra 3215 4WD
There are so many different brands of mowers available I am having a hard time narrowing them down. I will have approximately 3 acres of flat land to mow, which is a little rough in areas. I would like to keep the cost below 5K and would like at least a 46 in deck. I have been looking at the following brands and models: Husqvarna EZ5426, Hustler Sport or FasTrack, Toro Titan ZX 5000. Any recommendations or opinions on which to stay away from or which is best? What about a 3 point finishing mower that I can pull behind my Mahindra? I would think the zero-turn would do a better job with the finished look. Thanks.
/ Advice on purchasing a zero-turn #2
I just purchased a used 928d Grasshopper front mount 61"deck.I was thinking about buying new but I saw this mower on craigs list and checked it out and bought it for $5,ooo.oo.This is my first ztr and it's cut my mowing time in half,around 2 acres is what I usually cut and I used to use my Yanmar with a finish mower then I got ahold of a small JD 111. both got the job done but this grasshopper kicks b--- on grass.don't know where you are in Kansas but I can lead you to a local guy in Holton and opening a second place in Topeka that sells new and good used units. russ
Let me know. I am about an hour east of Topeka.
/ Advice on purchasing a zero-turn #4
I sent you a pm,let me know if you got it.sometimes my computer skills leave a lot to be desired. russ
Thanks for the response. I got it and will give them a call this week.
/ Advice on purchasing a zero-turn #6
If this property is the only one you have, or plan to have - I'd suggest attempting to get a demo of some type ztr mower before buying, even though various brands can ride quite differently. This will get you some idea what to expect. The ztr-style units don't work any faster on rough ground than other mowers. This is the advice I was given 5 years ago before I bought one and after mowing varied properties I can tell you they are'nt ideal for all places. If most of your area is open, you may prefer a finish mower behind your Mahindra. Good Luck choosing, hope you find your "ideal" mower.
/ Advice on purchasing a zero-turn #7
You're right about rough terrain slowing you down, but I still think overall if all you want to do is mow and get it done as quickly as possible, a ZTR is the way to go. For ~$4K, I'm pleased as punch with my new Cub Z-Force 44. I'm surprised at the amount of steel on the thing for the price. 11ga fab'd deck, wrapped with a 7ga skirt and 7ga top plate. Plus serviceable Hydrogear ZT-2800 transaxles that lots of entry commercial machines use now. Check my post here: http://www.tractorbynet.com/forums/cub-cadet-l-g/169684-bought-z-force-44-a.html
Joel
/ Advice on purchasing a zero-turn #8
Don't know much about Mahindra, is that some kind of a bait fish. However, if you got a 3 point hitch, go with a Woods finish, or something like it. If you are mowing every 3 or 4 week, you should be able to high gear it threw flat smooth stuff. Compared to a belly deck, a 3 pt. is warp speed.
2021 Polaris Ranger 1000 (A64047)
2021 Polaris...
TEREX LIGHT TOWER (A63569)
TEREX LIGHT TOWER...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
Volvo EC210CL Excavator (A64047)
Volvo EC210CL...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
JCT Skid Steer Snow Pusher (A64047)
JCT Skid Steer...
