Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly.
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly.
Do not pull on gear box, its most likely cast iron and brittle, you can shatter it..... I'm in favor of the already suggested heat and beat to straighten mounting deck...
You may not even need to heat.... Got 8lb sledge, a few good whacks may solve the problem....
That is what I am thinking. Got her flipped back upright so now to remove the gear box and see what we have.
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly. #12
I nave used a chain and a jack to straighten many things. Put the jack on the high spot and push it down:
Or pull up where it is too low:
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly. #14
First you need to flip it over and rotate the blades by hand to see if the gearbox shaft is bent as well. It would be a bad move to change things if the lean was providing the clearance because of a bent gearbox shaft. Also the same applies to checking for bent blades.
Frankly if everything clears and the only problem is a bent deck that the gearbox bolts to then I'd either remove the gearbox and bend the deck itself back straight with a long cheater through the gearbox mounting hole...., or else just leave it as is and use it as a leaner.
First step is the same though. Find the bend.
rScotty
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly. #15
I'd weld a plate to the deck and reattach the gear box with longer bolts. All of my RC's had more than enough space to do it.
OR
Just leave it. Doesn't look to be worth the fight myself.
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly. #16
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly. #17
If you try to jack it, you could bend the whole thing. If it bent one side up, is the other side bent down? You may not have hit anything. Heavy grass is tough on one.
I'd cut with a torch on the high ridge and try to beat it down. Torch cut will give it relief to collapse down. Then I would hit the scrap yard and buy some 1/2" plate minimum and make as big a washer as it will stand. Weld torch cut up. Cut holes for gearbox and bolts. Cut some holes in the washer so you can stitch the bottom to the top. Fill with weld and grind smooth. Leave a little reveal around g box hole so you can weld it. Weld around the plate washer. Use scrap to beef up your hitch. Then it will be the heavy duty hog you always wanted.
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly. #18
You could also try shimming the gearbox to correct the alignment.
So, the end result.
Pulled the gearbox. Measured on the deck at the mounting holes and one side about 1/8 inch higher than the other.
Beat on it with a 10Lbs sledge but it had little effect. The U channel underneath is just too thick and strong to really bend much. Got it better but still off.
A couple properly sized shims on the opposite side between gearbox and deck and we are as good as it is going to be.
Now measuring from edge of stump jumper to frame rail underneath then spun 180 and measure other side and it is 1/16 off.
Pretty good for a few hours and no cost.
Thanks for all of the suggestions on this. Very much appreciated.
   / Advice On How To Straighten Gearbox. Deck Mounting Point Bent Slightly. #20
The Gearbox mount area itself is still flat, that's important. Try using a sledge hammer with a block of wood on the deck to straighten the high side on the underside. Heat the entire area may possibly shrink it. Don't use water to cool it.
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
2014 International Derrick Digger Truck (A55973)
2014 International...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
