advice on dash repair - Ford 3000
   / advice on dash repair - Ford 3000 #1
eblanks
Clayton, NC
1967 Ford 3000, Bolens 1050 (year unknown)
When I bought my 67 Ford 3000 none of the dash instruments worked. Now that I've had a chance to get some other routine maintenance out of the way, I would like to tackle this problem. I have found several online resources to purchase the parts but now I'm left wondering where to begin. Should I buy everything from a new instrument panel, wires and everything or are there techniques to discover exactly what the problem is? As far as I can tell nothing works, the hour meter, tach, fuel and temp gauges are dead. The battery light does come on when I crank it but that's about it.
   / advice on dash repair - Ford 3000 #2
If nothing works, that might indicate a simple problem. I doubt ever guage has failed. If I were doing it, I would take the entire panel off and check for power, etc. See if one wire is damaged and the result is all gauges have failed as a result of one wire not providing power.
Good luck and post pictures!!!!!!!!!!
Bob
   / advice on dash repair - Ford 3000 #3
I doubt that everyone has failed like Doc Bob said. We have a 3000 and it has never had any lights or gauges replaced and its at 3500+ hours.
   / advice on dash repair - Ford 3000 #4
I bought a replacement instrument panel for my 4610 last month. It was Chinese made and the tach was frozen and broke my cable as soon as I started the motor. After working on the tach an hour to free it up and buying a new cable, it still didn't run very steady. The fuel gauge was very inaccurate also. The panel fogged up a lot where you could hardly see the gauges too. :( But it looked nice!
The Chinese one was a lot cheaper than the one from New Holland but I don't know if the NH replacement is the same as original or if it is Chinese made.
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51247)
JOHN DEERE 975 3...
1994 HONDA 300 FOURTRAX ATV (A51247)
1994 HONDA 300...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
