Buying Advice advice on a ford 1100
   / advice on a ford 1100 #1
kzoocarpenter
Hello I'm new to the forum, I'm looking for an older compact tractor to use a few times a year for my food plots. Right now I'm looking to buy just the tractor, and maybe a backblade for my driveway this winter. I've come across a 1980 ford 1100 for $1900. It looks to be in great shape. Thoughts on this tractor, anything I should know? Are parts readily available still? Thanks!
   / advice on a ford 1100 #2
The price is good if it looks good and has had regular maintenance. They are tough little tractors. The price is great if it's 4WD and has a hydrostatic transmission. Welcome to TBN!
Will it take standard three pt implements? I don't know a ton about tractors but from reading threads on the forum it looks like a handful of older tractors have a reverse pto etc. and will only take a specific brush hog or finish mower
   / advice on a ford 1100 #4
The 1100 will take standard implements. It works just like anything new.
TractorData.com has lots of info too.
   / advice on a ford 1100 #5
For food plots you will want 4x4 in a small tractor like the 1100. Those small tractors do not do ground engagement tasks very well without it.
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
2022 Bobcat T66 (A50120)
2022 Bobcat T66...
1000 gal Poly Tank (A50515)
1000 gal Poly Tank...
