Advice, getting stuff out your eyes
/ Advice, getting stuff out your eyes #1
Mith
Well on a slightly less humorus topic. /forums/images/graemlins/frown.gif Yesterday got a piece of dirt in my eye. Now nearly 24 hours later its still there. Its like having someone poke a needle in your eye every 5 seconds. My eye is watering so bad I can only see blurs and my other eye is blurey from birth. Really dont know how to get it out, have tried crying, eating loads of chocolate, splashing it with water, showering, eye bath thing, not coming out. Dunno what to do next except have a beer. Tried fabricating a lift linkage this morning but was having trouble. Is it possible that the dirt has come out and its a scratch or something? Scrathecd my eye a few years ago and it feels like that but cant remember too well.
Any ideas besides getting someone to look at it? Anyone with a sucessful idea gets a 4 packs of beer, its worth it to me honestly.
Thanks /forums/images/graemlins/wink.gif
/ Advice, getting stuff out your eyes #3
If it is still in there after that long, you need to see a doctor. I have had someone else take a match and hold my eye lid out. Then they can touch the match head to the piece of dirt and it will stick to the match. After this long, it may be stuck to the eye and causing damage. Go to the doctor.
Well I cant actuall see anything, that makes me think its a little scratch, might go to sleep now, see it that helps
/ Advice, getting stuff out your eyes #5
As others have said see a doctor. It is possible that you scratched your cornea.
Whenever I got something in my eye in the past instead of rubbing it I immediately flushed it with clean water. Rubbing your eyes with even a speck of dirt in one is what does the damage.
/ Advice, getting stuff out your eyes #6
"It is impossible to say how first the idea entered my brain; but, once conceived, it haunted me day and night. Object there was none. Passion there was none. I loved the old man. He had never wronged me. He had never given me insult. For his gold I had no desire. I think it was his eye! — yes, it was this! He had the eye of a vulture — a pale blue eye, with a film over it. Whenever it fell upon me, my blood ran cold; and so, by degrees — very gradually — I made up my mind to take the life of the old man, and thus rid myself of the eye forever. "
Edgar Allan Poe
/forums/images/graemlins/grin.gif
/ Advice, getting stuff out your eyes #7
I like the chocolate idea - shame it didn't work.
As long as there is no high-speed foreign-body injury (e.g.: working with a grinding wheel, hitting a metal hammer against a chisel), you can check things yourself.
Since you've tried washing out the eye, you've ruled-out the easily removable foreign body. One of three things have happened:
1. Foreign body lodged under upper lid.
2. Foreign body lodged on cornea.
3. Corneal abrasion complicating #1 or #2.
This is not really a do-it-yourself project - you'll need a helper.
For #1. You lay on your back, gently close your eyes. Your helper places a cotton-tipped applicator (in the US, a "Q-Tip") horizontally across the middle of the upper lid. While gently pulling up on your lashes, the applicator is pushed towards your chin. This will "evert" the lid. After eversion, a little backwards pressure on the lid margin will keep it everted. Look for a small speck stuck on the inside surface of the upper lid. It can be gently swept off with a moist cotton applicator.
For #2: Using a magnifying glass, the helper looks for something stuck on the clear portion of the eye. If found, you will need a doctor's help. These corneal foreign bodies usually end up being metal, and they are often steel pieces that stick to the front of the eye and actually rust onto the eye. The metal is easy to remove (by professionals), yet a small "rust-ring" may remain that needs follow-up care by an ophthalmologist.
For #3: If there is no inner lid foreign body, and no visualized corneal foreign body, you probably have a scratch. With no significant trauma or known object hitting your eye, you can give this 12-24 hours to see if it improves by itself.
Of course, this advice is provided by a professional stunt doctor on a closed course. Your mileage may vary.
/ Advice, getting stuff out your eyes #8
"Any ideas besides getting someone to look at it?"
Your eyes are worth the trip to the doctor.. he'd have you fixed up and feeling better!
It's miserable enough when it's happens for a few minutes.. don't drive yourself.. the pain in one eye can cause a reflex that forces you to shut both eyes.
/ Advice, getting stuff out your eyes #10
Glad you are OK. Had to have a sliver of steel removed by an eye Doctor. I was grinding on something AND using safety glasses. There is no substitute for the doctor when you gotta have one.
/ Advice, getting stuff out your eyes #11
Glad you are okay. This story was reminding me of when I had a spec of rust (working under the car) get in my eye, and I couldn't see anything. Finally went to the Dr. and he picked out the rust. It had embedded itself, and 20 years later, when I get my eyes checked, they comment on the scar that they can see. No vision impairment, but I consider myself lucky.
Friend of mine learned oneday, when one eye suddenly went blind, that he had a small metal filing floating in his eye. He remembered getting it in there some many years prior. The thing these days is the MRI exams, when they ask if you have any metal in you. Such a spec of metal in the eye can be pulled right out during the MRI (magnetic resonance imaging) procedure.
Which also reminds me of a couple months ago, I was drilling steel, and at the moment I remembered to put the safety goggles on, I felt something lightly hit my eye. I located a magnet, and held it to my eye, and felt the metal chip come out and could see it on the magnet. Felt lucky.
/ Advice, getting stuff out your eyes #12
Glad to hear everything is OK.
I once poked my eye on a branch from the hedges by my moms garbage cans as I bent over to pick something up. I can't remember how long it was before I saw the doctor (a couple of days maybe) and he found that I had a scratch/cut on my eyelid. Every time I would blink, it would rub and irritate my eye making it feel like there was something in there when actually there was nothing. He prescribed some type of eye drops that would put a little film between my eye and the lid to help with the irritation and to help heal the scratch/cut faster. Just thought I would post this for future reference.
/ Advice, getting stuff out your eyes #13
If you get something in your eye, rub the OTHER eye. That will force both eyes to water and maybe flush it out.
If you rub the eye that the object is in you stand a chance of doing further damage.
Plan B: Try flushing with clean water, that will sometimes dislodge it.
Plan C: FInd a friend (with clean hands) and have him/her look. If friend will hold their finger up and move it side-to-side and upan down while you follow their finger with your eyes you will move your eyeball and they may be able to see if there is anything in it.
If in doubt, see the Eye Doc.
Off Topic:
Welder and brand new helper working on a job all day. Each time Welder prepares to strike an arc he issues warning "Watch it!".
About 4 PM Welder prepares to strike an arc and says "Watch it!". Helper replies, "Mister you will have to watch it yourself this time, I can't see it any more".
Bill Tolle
/ Advice, getting stuff out your eyes #14
My advice is to see an Optomotrist immediately. (but now you have it fixed which is good)
My story, 7 pm working on a belt grinder dressing some steel, safety rated glasses with side shields on and feel a speck fly up into my eye..
Shower / eye wash / artificial tears, natural tears,,, try and sleep, 2 am going insane and go to the ER wanting to rip my eye out, doc gets out the magnifier and the dye "nothing there" they rinse and I feel it come out. Glad nothing was there, just felt it come out...... Dr. tells me and my wife that it was all in my head. Thanks.....
3 weeks later at my optomotrist getting a laser eye exam (worked around live lasers a lot) and he says, did you get a piece of metal in your eye a couple of weeks ago? I reply I thought I did, but the ER doc said no, He then takes a picture of my eye for me to show to the wife to show the rust stain it left on my eyeball. He said call him anytime I have an eye problem, that I went to a car mechanic when I needed a fuel injection specialist.
/ Advice, getting stuff out your eyes #15
Well I have only one eye. The other is plastic. Having suffered a mishap with a tractor no less. So -
Go to a doctor, an ophthalmologist is preferred. They are trained to do surgery, if one suspects something in the eye.
Do wear saftey glasses, HIGH quality.
Blind is not closing your eyes. Blind is the darkest dark you can imagine.
Get your eyes checked yearly too.
'nuff said. Hope your eye gets better.
Oh... eyes have a nasty natural phenomenon of possibly getting worse, when damage to one eye occurs.
-Mike Z. /forums/images/graemlins/grin.gif
/ Advice, getting stuff out your eyes #16
GO to the Dr. Many years ago i had a cinder blow into my eye, as luck would have it was at the time working at a hospital on the 3rd shift went to emergency Rm and they could not get it out, in the AM when the eye Dr. came in HE got it out in 10 seconds, but the eye was scratched up pretty bad, so i had to use Meds and wear a patch for a few days. Don't mess around!!! Get it checked.
/ Advice, getting stuff out your eyes #17
My wife has this wonderful eye condition called recurring corneal abrasion. Years ago while working in her flower garden, she bent over and the "killer azalea" scratched her cornea. Now she has to put some goo in her eyes every night, because if they dry out while she sleeps and she opens her eye, it tears her cornea again, in the same place, which of course causes excrutiating pain and a trip to the emergency eye doc. Then the only solution seems to be to wear a clear contact lens for a few days to two weeks and take some antibiotics, the eye heals pretty quickly, at least until the next time it does it....................
Moral of the story, be careful with your eyes, and go see the doc immediately if you get something in it or hurt it in any way.
2025 Swict 66in. Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2018 International HX620 Quint Dump (A62613)
2018 International...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
