s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,608
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
Since new, the front bucket on my L3200 has been about 3/8" higher on one side than the other. Never really bothered me or affected use, and I figured I'd give it a few hours to see if the frame settled in. Well, at 60 hrs now, there hasn't been a real change. I am wondering if I should loosen up the FEL frame mounting bolts and put some pressure on the bucket to see if that evens things up.
The real question is how much slop there is in the mounting holes; with all those bolts on each side, I can't imagine I'd get a whole lot of movement, but maybe someone has seen the hole sizing and knows. It probably wouldn't take more than 1/16" - 1/8" of slop at the frame end to absorb 3/8" at the end of the loader arms.
BTW, in case anyone is wondering, nothing is bent and it's not a tire pressure or ride height issue. I can see the left cylinder is always extended about 1/4" more than the right, so it's got to be in the loader arms and frame mounting somewhere. If I let the loader travel to the limits in either direction, the cylinders will even out and I can see the arms tweak themselves into alignment (temporarily).
thanks,
219
thanks,
219
