Mowing Adjusting turnbuckle
/ Adjusting turnbuckle #1
jveretto
Buffalo, TX
Kabota L2800
I hooked up my new 4 foot mower to new L2800 tractor. It appeard the turnbuckel needs one end to have reverse threads but does not. I cannot take the swing out of the mower because turning turn turn buckle does not tighten up because both ends thread the same way. What am I doing wrong?
/ Adjusting turnbuckle #2
What does the other turnbuckle do?
James K0UA
Good question. I guess it's possible the other one does the tightening. Thanks. Should have checked before posting. I'll check in the morning.
/ Adjusting turnbuckle #4
My point was to for you to compare them. They both should become shorter when turned one direction, and longer when turned the other. sounds like a defect for the dealer to look at to me. if they are not alike.
James K0UA
/ Adjusting turnbuckle #5
James K0UA
I agree, defect. Sounds like the turnbuckle was made wrong then assembled with threaded parts that fit but do not function properly. A case of two, or more, wrongs making a wrong.
1987 Asphalt Tanker Trailer (A65563)
1987 Asphalt...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
