Mowing Adjusting turnbuckle
/ Adjusting turnbuckle #1
jveretto
Buffalo, TX
Kabota L2800
I hooked up my new 4 foot mower to new L2800 tractor. It appeard the turnbuckel needs one end to have reverse threads but does not. I cannot take the swing out of the mower because turning turn turn buckle does not tighten up because both ends thread the same way. What am I doing wrong?
/ Adjusting turnbuckle #2
What does the other turnbuckle do?
James K0UA
Good question. I guess it's possible the other one does the tightening. Thanks. Should have checked before posting. I'll check in the morning.
/ Adjusting turnbuckle #4
My point was to for you to compare them. They both should become shorter when turned one direction, and longer when turned the other. sounds like a defect for the dealer to look at to me. if they are not alike.
James K0UA
/ Adjusting turnbuckle #5
James K0UA
I agree, defect. Sounds like the turnbuckle was made wrong then assembled with threaded parts that fit but do not function properly. A case of two, or more, wrongs making a wrong.
International 2000 End Loader (A66408)
International 2000...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
200 gal Poly Tank (A66408)
200 gal Poly Tank...
2005 Lexus ES Sedan (A64194)
2005 Lexus ES...
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
