Box Scraper Adjusting Three Point Hitch for new Box Blade
   / Adjusting Three Point Hitch for new Box Blade #11
Soundguy said:
One thing.. to help prevent confusion in the future.. your lower links are called 3pt lower lift arms.
soundguy
I've been calling them "lower links" because that is what the Kubota manual calls them. However, it appears that "lower lift arms" is what is more commonly used on TBN.
Chris
This weekend I made a tweak to the box blade that dramatically improved the bite I could get from the scraper blade. You'll note in the photo below the two metal bars that run from the back of the box blade up to the mount point where the top link attaches. Normally those bars would attach a couple inches below that point, where you can see the original silver bolt that held them in place.
After thinking about it I decided to give it a shot, and the bars moved easily enough (took a little leverage of course).
End result, you can see the dramatically increased height difference between front edge of the box and the back edge. And if that angle proves to be too severe, I can now reduce it by extending the length of the top link.
Just an interesting lesson learned that I thought other newbies might be interested in.
Thanks,
KVMAPR
   / Adjusting Three Point Hitch for new Box Blade #13
Be prepared to deal with bent diagonals
//greg//
   / Adjusting Three Point Hitch for new Box Blade #15
Rob, wake me up when we get to the "training wheels" part of the thread, OK? Good Luck Kvmaper.
Jake
   / Adjusting Three Point Hitch for new Box Blade #16
john_bud said:
You want the front of the box to be 1.5" to 4" lower than the rear depending on soil, job etc. Normally it's in the 1.5" range for scraping.
Measure your top link (from the lowest 3pt hole on the tractor side) to the box mount with the box tilted to that 4" angle. That will be your extreme shortest top link.
If you are having a hard time getting one that short for some reason, you can buy some of Pat's Quick Hitches as seen on this site. That will move the 2 mounting arm points back about 3-4".
jb
I've not hardly used my boxblade. Am making some mental notes here.
1.5" = scrap
4" = dig with rippers?
What about to smooth?
   / Adjusting Three Point Hitch for new Box Blade #17
rcrcomputing:
Box blading well takes a lot of practice. To smooth I would raise the scarifiers and extend the top link cylinder length somewhat. Depending on the quality of "smooth" I might also raise the three point lower lift arms. I also agree with greg g about the possibility of bending the BB's diagonals. Be careful using the BB as a dozer blade. I tend to only use my BB that way when pushing snow and/or the material I am working with the BB. Jay
   / Adjusting Three Point Hitch for new Box Blade #18
Scarifiers up like Jay said.
To smooth, what I do is make the boxblade sit on level ground so BOTH the front and rear blades touch the ground...but so as the rear blade touches slightly more than the front. I don't want to say place the boxblade level to the ground, (looking from the side) but more specifically the blades themselves ... in case the blades and the boxblade don't line up when level.
In doing so, your front blade still cuts off any bumps and still fills any divots and the rear blade uses the rounded part to put a smooth finish on. If your surface is already how you want it, you want to tilt the box backwards so ONLY the rear blade is touching the ground. Now all it does is smooth out the surface without cutting anything.
   / Adjusting Three Point Hitch for new Box Blade #19
Rob, I've been slowly learning how to use my box blade with the help of the many threads on this board.
This last post of yours caught my interest because it describes something that I haven't been able to do yet... I think. When my top link is shorted, I have the scarifers ripping. With the top link lenghtened, the blade is scraping and I will fill the box in short order.
Finding a setting that would allow me to smooth without filling the box per-se would be ideal now that my drive is cut nice and smooth.
Are you suggesting that my top-link should be somewhere within short and long to achieve this nirvana? I imagine that my scarifers might still touch the ground if I had the top-link somehwere in between. Maybe I should just take them off?
Would appreciate any more thoughts that might clarify this for me.
   / Adjusting Three Point Hitch for new Box Blade #20
I bought a box blade for my Jinma 284 and cant get it to set level and wont go down to the ground enough.The middle turn buckle is adjusted all the way in.Also does the two left and right turn buckles should be adjusted even?
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
John Deere 980 Field Cultivator (A59814)
John Deere 980...
