Adjusting steering wheel play
   / Adjusting steering wheel play #1
Big Irish
collinsville il.
ford 2000 & ford 900
What's up guys, I need you knowledge on if I can take some of the play out of the steering wheel. It's on a Ford 2000 with power steering. Seems like a lot of play, thought I'd adjust while I have it apart. Also will I have to bleed the air out because I've replaced all the lines to the resiviour and I've had the resiviour off and apart to clean. Sorry for the spelling my spell check isn't working. Thanks
   / Adjusting steering wheel play #2
Put these questions on the Ford forum and Sound Guy will find them. Don't give up so easy.
   / Adjusting steering wheel play #3
Bleeding generally consists of turning the wheel back and forth going to each end of the wheel travel multiple times. That may get some of the play out if its being caused by air pockets. Otherwise, you will need to watch and see where the play is being introduced.
Aaron Z
   / Adjusting steering wheel play #4
Steering "play" is most often due to worn steering linkage parts like rod ends, king pins, etc
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
