Adjusting steering wheel play
   / Adjusting steering wheel play #1
Big Irish
collinsville il.
ford 2000 & ford 900
What's up guys, I need you knowledge on if I can take some of the play out of the steering wheel. It's on a Ford 2000 with power steering. Seems like a lot of play, thought I'd adjust while I have it apart. Also will I have to bleed the air out because I've replaced all the lines to the resiviour and I've had the resiviour off and apart to clean. Sorry for the spelling my spell check isn't working. Thanks
   / Adjusting steering wheel play #2
Put these questions on the Ford forum and Sound Guy will find them. Don't give up so easy.
   / Adjusting steering wheel play #3
Bleeding generally consists of turning the wheel back and forth going to each end of the wheel travel multiple times. That may get some of the play out if its being caused by air pockets. Otherwise, you will need to watch and see where the play is being introduced.
Aaron Z
   / Adjusting steering wheel play #4
Steering "play" is most often due to worn steering linkage parts like rod ends, king pins, etc
378812 (A51573)
378812 (A51573)
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
2020 Nifty Lift TM34TG (A51573)
2020 Nifty Lift...
