Adjusting Kioti RX7320PC Lower Links
   / Adjusting Kioti RX7320PC Lower Links #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I have a 2015 Kioti 7320 and want to adjust one of the lower links to level my brush hog side-to-side. Looking at the 3PH from the back, the lower link has an adjustment lever that raises or lowers the link. The other lower link does NOT have the lever nor any way that I can see to raise or lower it. Is this lower link supposed to raise or lower when I use the lever on the other lower link to raise or lower it?
   / Adjusting Kioti RX7320PC Lower Links #2
Its just like every other tractor you only adjust one side to level it.
   / Adjusting Kioti RX7320PC Lower Links #3
Left side is fixed, right side is adjustable?
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58216)
8 TOOTHED BUCKET...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
Eagleline 3Pt 6' Box Blade (A57148)
Eagleline 3Pt 6'...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
