Adjusting FEL Wedges
   / Adjusting FEL Wedges #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I've got to adjust the wedges on my 670.
Any body done this? The manual is fairly straight forward, but says to drop the front pin down 1" No picture of this and I see no movable pins forward.
Any tips, y'all?
   / Adjusting FEL Wedges #2
I did this once on my 790 w/ 70 loader. It was pretty straightforward. As far as dropping the pins... make like you are going to remove the loader by releasing the latches, then lower the front support (raise the loader) just an inch. The front support will come off the tractor frame-mounted pins by an inch. Then loosen the wedge bolts, tap the wedges down and retighten. It's a lot easier to do than describe /w3tcompact/icons/smile.gif
Thank You!!
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
