Adjusting FEL Wedges
   / Adjusting FEL Wedges #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I've got to adjust the wedges on my 670.
Any body done this? The manual is fairly straight forward, but says to drop the front pin down 1" No picture of this and I see no movable pins forward.
Any tips, y'all?
   / Adjusting FEL Wedges #2
I did this once on my 790 w/ 70 loader. It was pretty straightforward. As far as dropping the pins... make like you are going to remove the loader by releasing the latches, then lower the front support (raise the loader) just an inch. The front support will come off the tractor frame-mounted pins by an inch. Then loosen the wedge bolts, tap the wedges down and retighten. It's a lot easier to do than describe /w3tcompact/icons/smile.gif
Thank You!!
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2011 Kia Forte Sedan (A55853)
2011 Kia Forte...
2019 Ford Escape S SUV (A55853)
2019 Ford Escape S...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
