Adjusting Brakes
/ Adjusting Brakes #1
Chris611
I am in the process of installing new brake plate assemblies on my 2008 LoadMax 14k gooseneck. It has AL-KO axles. I bought AL-KO 2" x 12" replacement brake plate assemblies from Southwest Wheel for all 4 locations. Then install has went pretty well. When I look at the instructions online for the brake assembly, they say to tighten the shoes until the wheels don't rotate, then back them off until the tire will rotate 3/4 of a revolution. My question is what does that exactly mean? So if it give it a "Price is Right" wheel spin, does it stop at 3/4" rotation? Do I give it a gentle push and it should stop at 3/4 rotation?
Any help would be great.
Thanks
Chris
/ Adjusting Brakes #2
Yes. I adjust till I can not rotate then back them off till just a slight drag so they wear in.
You must adjust to lock up first to center everything up in the drum.
Chris
/ Adjusting Brakes #3
I have found it is usually 5-10 clicks back from full tight. Chris is right, you need to tighten them all the way up first to center the shoes. The 3/4 turn thing is a bit subjective in my opinion. I try to keep similar drag on all the drums when I adjust them too.
Brian
2021 KUBOTA SVL75-2 SKID STEER (A65053)
2021 KUBOTA...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
Honda EM 7000is Inverter Generator (A64553)
Honda EM 7000is...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
