Adjustable side link stuck
   / Adjustable side link stuck #1
TigerfaninAR
Central Arkansas
Kubota B2320 FEL, MMM
New to me tractor (used B7300) and the adjustable side link is stuck like nothing else. The adjustable part that lets you swing the arms wider was stuck but after a little oil and elbow grease all works well. Didn't work for the side link. How forcefull can I be? Any product that works better than others? Thanks
   / Adjustable side link stuck #2
Soaking in PB blaster may help along with a little tapping from a hammer. If you have a torch try heating it up before the PB stuff to see if that will break the bond.
   / Adjustable side link stuck #3
If you are talking about the turnbuckle system, if they stay frozen and need to be replaced, you might consider replacing them with the telescopic stabilizers. I changed the turnbuckle system out on mine because I had bent a couple of the bolts and the telescopic system has the benefit of much easier adjustability and it holds the lower control arms spread apart at whatever width you set at instead of them collapsing in. I also have the Pats Quick change system, so I no longer have to use the spreader bar to hold mine apart when I am hooking up implements.
Stabilizer
Thanks :thumbsup: Will try the PB before spending the money on the telescopic system, but that sure looks nice.
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A53843)
2015 MACK CHU...
7061 (A53421)
7061 (A53421)
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
2002 MACK CH (A53843)
