Adjust loader pressure on LS made Montana 4344
   / Adjust loader pressure on LS made Montana 4344 #1
blt93932
Woodbine, Georgia
looking
Does anyone know where the loader bypass adjustment is located on a Montana 4344? C7DAC3AA-0A8B-4945-BFB1-13EB1D67CA69.jpeg0BF1BEAC-4855-4E81-B927-A2F9686C95E0.jpegA1376AE9-8025-4EED-A080-8DB82EDA78D1.jpegFF105706-D6C7-4059-A907-18CA1C9DA066.jpeg
   / Adjust loader pressure on LS made Montana 4344 #2
Fallow the pressure line coming from the pump. It might come to a relief valve before it goes to the loader valve. The valve block in the picture doesn't seem to have a relief port/adjustment screw, which is usually a hex set screw with a locking nut on it.
I'll have to check for that, seems like this might be a nimco loader valve, and might be non-adjustable, not sure if that means it's set to whatever the system is or it's own setting though.
   / Adjust loader pressure on LS made Montana 4344 #5
That is definitely a relief port, (the set screw and nut) the question is... where is it at in regards to the loader valve? is it before? if its after it will only provide relief for the 3 point...
Just loosen the nut and give the screw a half turn in (clockwise)... see if it does what you want... Anything more and you will want to put a pressure gauge on the system to prevent damage.
It is before the loader valve, will try adjusting tomorrow!
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
Landoll Hauloll (A53472)
Landoll Hauloll...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
