Adjust loader pressure on LS made Montana 4344
   / Adjust loader pressure on LS made Montana 4344 #1
blt93932
Woodbine, Georgia
looking
Does anyone know where the loader bypass adjustment is located on a Montana 4344? C7DAC3AA-0A8B-4945-BFB1-13EB1D67CA69.jpeg0BF1BEAC-4855-4E81-B927-A2F9686C95E0.jpegA1376AE9-8025-4EED-A080-8DB82EDA78D1.jpegFF105706-D6C7-4059-A907-18CA1C9DA066.jpeg
   / Adjust loader pressure on LS made Montana 4344 #2
Fallow the pressure line coming from the pump. It might come to a relief valve before it goes to the loader valve. The valve block in the picture doesn't seem to have a relief port/adjustment screw, which is usually a hex set screw with a locking nut on it.
I'll have to check for that, seems like this might be a nimco loader valve, and might be non-adjustable, not sure if that means it's set to whatever the system is or it's own setting though.
   / Adjust loader pressure on LS made Montana 4344 #5
That is definitely a relief port, (the set screw and nut) the question is... where is it at in regards to the loader valve? is it before? if its after it will only provide relief for the 3 point...
Just loosen the nut and give the screw a half turn in (clockwise)... see if it does what you want... Anything more and you will want to put a pressure gauge on the system to prevent damage.
It is before the loader valve, will try adjusting tomorrow!
2025 Spirit 48V 1000W All Terrain Electric Bicycle (A55853)
2025 Spirit 48V...
Year: 2018 Make: Ford Model: Fusion Hybrid Vehicle Type: Passenger Car Mileage: 51,578 Plate: Body (A56859)
Year: 2018 Make...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
54in Fork Attachment (A55851)
54in Fork...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
