Adjust lift capacity and height of three point
   / Adjust lift capacity and height of three point #11
The picture in your manual is identical to my 2320. Looks like they changed the new tractors and used the old photo.
   / Adjust lift capacity and height of three point #12
Do you know the reason why some tractors have adjustment holes on the draft links Some don't.
I'm not sure. Seems to be more common in larger CUTs, Utility and small AG tractors.
I'm a maximum height guy so mine are normally pinned closest to the tractor end of the lower arm.
   / Adjust lift capacity and height of three point #13
My service manual says 2025R & 2032R, does anyone know why I don't have as many adjusting holes as the manual says?
View attachment 494337 end quote
The hole seen in your pic of the lifting rod sturip isn't for adjustment, it is to small for the pin to fit in. I suspect it is a location hole for a welding fixture so the part could be welded in the proper orientation.
Good catch!!!!! You are exactly right!!!!! I've saw pics of those before and never caught that!!!! Thanks for the clarity!!!! :)
   / Adjust lift capacity and height of three point #14
Here's a pic of my Kubota set for maximum lift height for reference.
Ding, Ding, Ding, give that man a prize, right you are sir that hole is to small for a pin and that's why the manual does not mention lift or capacity adjustment for the 2032R.
   / Adjust lift capacity and height of three point #16
My 2025R has 3 holes in the lift arms and 3 holes in the split arms that go over the solid arms. They may have installed the wrong lift arms on yours. I'd ask the dealer for a technician to come out and check, maybe bring the correct lift arms.
Immediately replace the pins they supply. It's far too easy for brush to push those pin securements they supply out of the pin holes. Happened on me. I immediately went to TSC and bought some other pins and securements.
   / Adjust lift capacity and height of three point #17
Here are a couple pics of both sides of my 2025R lift arms and a 3rd picture of the TSC pin I got with the securement that cannot be pushed out by brush.
   / Adjust lift capacity and height of three point #18
Now that's an adjustable 3pt!!!! :)
   / Adjust lift capacity and height of three point #19
If you move pin from LOWER hole on left and right Lifting Rod stirrups to TOP hole on left and right Lifting Rod stirrups, your three point hitch will lift approximately five inches higher at the Bull's Eyes.
Is 5" of additional lift going to give you what you need?
BigTiller got it right, by noticing I have no adjustment because the top hole is to small, I own a 2032R not a 2025R but the manual covers both models, so the 2025R has lift and capacity adjustments and the 2032R does not.
thanks for posting those pics
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2006 APPA TL (A55787)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
