Additional lighting on Curtis Cab
/ Additional lighting on Curtis Cab #1
jdgreg
Warrenton, Va
Just put my Curtis soft side cab on my 4210 /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif , and thought I'd get some aux lights from TSC for the top, I didnt order them when I ordered the cab.
My question is about the amp load of the addl lights, and how would be the best way to wire them up. I'm thinking about using a relay with the trigger driven by the current front lights, and Pos straight from the battery.
/ Additional lighting on Curtis Cab #2
50 watt lights draw about 4 amps each. Using a relay would be the BEST way to add more lights to your cab, then no additional draw is placed on the factory wiring harness.
My only change to your plan would be to trigger the relay from another source that is ON with the key, and wire in an additional switch to control the new lights. That way you can have the cab lights on without the headlights to help reduce strain on the battery/alternator.
Sounds like a nice setup! /forums/images/graemlins/grin.gif
Well, I took most of your advice, I installed a switch to turn the aux lights off and on, seperate from the headlights. I can believe the amount of light they throw out compared to the headlights. /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif Bigtime improvement, and realtively inexpensive. Next time it's light out and I have the camra handy, I'll post some pics of the cab set up. I also wired in a small ceramic heater, for those really cold days coming up. /forums/images/graemlins/wink.gif
/ Additional lighting on Curtis Cab #4
<font color="green"> Pick up power from a source that is on with the key, and wire in an additional switch to control the new lights. That way you can have the cab lights on without the headlights to help reduce strain on the battery/alternator.
********************** </font>
<font color="purple"> He could put a seperate switch for each light to allow the choice of either one or both lights at once.
I would mount the lights so they can be rotated 360 degrees and swivel up and down. </font>
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
2005 CLUB CAR CARRYALL UTV (A64280)
2005 CLUB CAR...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-250...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
