Adding Work Lights Question
/ Adding Work Lights Question #1
Tractor Tom
New Brunswick, Canada
Kioti CK35 H
Can anyone explain to me why a relay switch is needed or used when hooking up more then a couple of work lights? I guess I’m not sure what a relay switch does?? I have two lights on the rear of my CK20 wired without a relay, and would like too add two on the front as well. Thanks for the help.
/ Adding Work Lights Question #2
Relays are used to handle high current. The automotive style relays I use are rated at 30 amps. Most switches are only rated at about 10 amps or so, and some of the nice looking small ones are only rated at about 5 amps. The use of the relay also allows you to run lighter gauge wire up to the switch because you are only switching the relay, not the current draw of all the lights.
If you have two 50 watt lights, then your are pulling about 8 amps.
/ Adding Work Lights Question #3
The relay allows your dash switch to only use a small amount of current to throw a bigger switch in the relay which connects the larger current load of your lights. Without a relay, the dash switch would be passing the full current to the lights and would melt. Also a relay allows you to pull the huge current for the lights right from the battery instead of a dash circuit.
/ Adding Work Lights Question #4
You still want to add an in-line fuse to protect the wiring and relay. If your relay contacts are rated at 30 amps and you run #10 AWG wire you can fuse for a max of 30 amps.
Thanks for the replies, I now have a better understanding of what a relay does and why I need to use one when hooking up my work lights. Thanks again or the help. This is a great website!!!! If you have a question, you’ll get an answer.
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
BUYERS PREMIUM & PAYMENT TERMS (A59910)
BUYERS PREMIUM &...
2019 RoGator RG1300C Spreader (A63109)
2019 RoGator...
Ag Leader Integra Screen (A63116)
Ag Leader Integra...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
