Adding two spool valve to Kubota L3200
   / Adding two spool valve to Kubota L3200
Thanks.
So let me see if I am following this right...
-Disconnect the power beyond at the block under the drivers right foot. (This is the one at the upper left correct?)
-Connect the disconnected hose into the new valves power beyond in.
-Run the Power beyond out from the new valve back to the one that was disconnected under the drivers right foot.
- Tee the tank return line from the new valve into any convenient tank return line
- Run new supply lines as needed to grapple or rear remotes
Does this sound right?
   / Adding two spool valve to Kubota L3200 #13
Thanks for that. I tried looking for pictures on the detent add on kit and could not find any.
I am picturing it going between the joystick and the valve?
Also if anyone could advise on my post regarding which hose I disconnect and reconnect I would appreciate it.
Also, the total flow for my tractor is 10.5 gpm. 4 is dedicated to steering, and the other 6.5 is for other things.
8gpm valves is what I want correct?
   / Adding two spool valve to Kubota L3200 #16
The attachment should help.
Brian,
I cant see the attachment. Not sure if I am doing something wrong.
Brian, that is amazing. Thank you so much!!!!
Just click on this and the picture should come up.
Brian,
I just went out and compared my tractor to your picture. I do not have a hose in the background as your picture does. I have the three attached to the front of the block. The other connections are all hard piped.
Can you help clarify?
Thanks
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
BLAST SHIELD (A50854)
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
