Adding two spool valve to Kubota L3200
   / Adding two spool valve to Kubota L3200
Thanks.
So let me see if I am following this right...
-Disconnect the power beyond at the block under the drivers right foot. (This is the one at the upper left correct?)
-Connect the disconnected hose into the new valves power beyond in.
-Run the Power beyond out from the new valve back to the one that was disconnected under the drivers right foot.
- Tee the tank return line from the new valve into any convenient tank return line
- Run new supply lines as needed to grapple or rear remotes
Does this sound right?
   / Adding two spool valve to Kubota L3200 #13
Thanks for that. I tried looking for pictures on the detent add on kit and could not find any.
I am picturing it going between the joystick and the valve?
Also if anyone could advise on my post regarding which hose I disconnect and reconnect I would appreciate it.
Also, the total flow for my tractor is 10.5 gpm. 4 is dedicated to steering, and the other 6.5 is for other things.
8gpm valves is what I want correct?
   / Adding two spool valve to Kubota L3200 #16
The attachment should help.
Brian,
I cant see the attachment. Not sure if I am doing something wrong.
Brian, that is amazing. Thank you so much!!!!
Just click on this and the picture should come up.
Brian,
I just went out and compared my tractor to your picture. I do not have a hose in the background as your picture does. I have the three attached to the front of the block. The other connections are all hard piped.
Can you help clarify?
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
TMA (A49461)
TMA (A49461)
