Adding two spool valve to Kubota L3200
   / Adding two spool valve to Kubota L3200 #1
Appalachia
Black Mountain, NC
Kubota L3200
Hello all,
I have done a lot of research, and I think am on the right track, but I want to ask the experts here before I order the wrong thing.
I currently have hydraulics for the three point lift, front end loader, and also the hydrostatic transmission.
I want to add an additional two spool valve. One to run a grapple, the other to run one set of rear remotes. The biggest need for the rear remotes is for running a post driver which needs continuous flow to be controlled with its own valve. So a valve with detent would be ideal, but could be done with a bungee cord if necessary.
What I think I need to buy is a two spool valve that is capable of power beyond and open center. And then of course new hoses.
I will need to set up the valve to have power beyond in and power beyond out in series with the other power beyond hoses. And then a tank return (which I can 鍍ee in with any tank return line).
Does this all sound correct?
If anyone would be willing to post a link to an appropriate two spool valve I would greatly appreciate it. There are roughly 800 million out there and I am having trouble selecting the correct one.
Thanks
   / Adding two spool valve to Kubota L3200 #2
Sounds like a plan. Insert the valves into the PB loop between the loader and 3-pt hitch. You'll find there is a hose that runs from the loader valves to the 3-pt hitch that connects at the hydraulic block under the foot platform -- that's where you can insert your valves.
Kubota makes a nice factory kit for the L3200 with stackable valves and it mounts to the right side of the seat next to the 3-pt hitch lever, but it costs more than generic valves of course. You can stack 1, 2, or 3 valves there, of several different varieties.
   / Adding two spool valve to Kubota L3200 #3
You can do “stacking” valves which would leave the option to expand in the future. Plus each valve can be exactly what you want.
I don’t think you need PB and a return line if it’s just coming off the loader valve and nothing further down the line.
   / Adding two spool valve to Kubota L3200 #5
Whenever I have needed hydraulic support beyond my knowledge, I have found Cross Manufacturing a great way to go.
You get to talk to real "tech" people.
There are may options for valves and if you pick one of the shelf, after a little while you may find yourself cursing it for the rest of the tractor (or your) life.
Valves
Detents, float position, load checks.........
Dave M7040
Thanks.
I thought about the kubota version but would like to do it cheaper.
So what I need is a directional control valve? What does the SV and all the other versions mean?
I understand that stacking would allow the system to be expanded. But what do you mean allow each one to be exactly what you want?
   / Adding two spool valve to Kubota L3200 #7
Thanks.
One valve with detent to hold open, one that has return to center etc. Plus you can change locations like detent valve on left or right.
   / Adding two spool valve to Kubota L3200 #8
The 3-pt hitch has to be last in line on the L3200, so it will have to be downstream of any rear remote valves that get added. Normal order on this tractor is Pump > Loader > Remotes > Backhoe > 3-pt.
Any remote valves will need to pass through PB to next in line and have their own return.
The Kubota valves stack onto to the side of the transmission case and use a return port built into the case for that exact purpose. If someone were to machine a block with o-ring groove, they could also use this return port for a custom third-party setup.
   / Adding two spool valve to Kubota L3200 #10
This video shows the theory of connecting a new valve to an existing one that has power beyond (like a loader valve): Hydraulics Pro Club - Knowledge YOU Can Use For YOUR Success
neat hydraulic modelling software he's using.
The new valve he adds does not have PB- all output goes out one port not two. My limited understanding is that you can have more than one additional valve that do not have PB and T separate. That's how my Branson's two remote valve bodies were set up from the dealer.
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
JLG 1255 Telehandler (A51039)
JLG 1255...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
Unused Delta Crash...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
