/ Adding TNT, TOP N TILT, TOP AND TILT TO KUBOTA B7800 (WORK IN PROGRESS) W/ JOYSTICK
When you ask about a loader valve, are you wondering if it has regen? No it does not. And as far as I know of, loader valves are typically mono block valves, not stacking valves. Both spools have the float function as does 2 of the 3 in the set that Fallon has. By the way, the joystick is custom made to work with both valves having the float function. That is not a std item.
Brian, Thanks for answering that, I wasn't sure of the correct answer, sometimes people get a little more technical or sound more technical than need be. I am in no way an expert in hydraulics, in fact the total opposite, don't know jack diddly about it but I am learning a little...
