Adding some more bite to my grapple
/ Adding some more bite to my grapple #1
MaineTom
China, Maine
Kubota - BX25D
I have a Land Pride SGC0548 grapple on my BX25D. It works great for picking things up that are perpendicular to the grapple, but if you need to pick something up, like a smaller log, and want to pick up the end, you need something like this. I have a pine grove that has a lot of dead falls. The live trees are far enough apart that I can drive the BX25 between them, but I need to pick the dead falls up by the end so I can then "skid" them out backwards. :thumbsup:
So I added a couple of pieces of 1" angle iron to the grapple teeth. I ground notches in the teeth where the "j-Bolts" go so they would not slip out. I used 5/16" J-bolts and cut them to length after I put a lock nut in place. I think I can use this same technique to make some bolt on forks for the grapple. :D
/ Adding some more bite to my grapple #2
Looks functional.
Here's the mouth of a Wicked Grapple, which is very effective for what you're describing!
Travis
Yes that looks like it would work quite well. I've been using mine to clear the edge of a field, and there are some roots left over that I should be able to grab with my modification.0811151132.jpg
/ Adding some more bite to my grapple #4
Seems like the thing to have on occassion. I just wonder if there is a down side. Law of unintended consequences, that sort of thing. I'm thinking just one jaw in the middle is usually all I would need
That's basically what I did. I could have gone all the way across the grapple but chose to just do the minimum needed.
2014 IC Corporation PB105 School Bus (A64194)
2014 IC...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2020 BOBCAT E35i EXCAVATOR (A65053)
2020 BOBCAT E35i...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
1994 Peterbilt 377 T/A Sleeper Cab Truck Tractor (A64194)
1994 Peterbilt 377...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
