Adding rear remotes on a small tractor
/ Adding rear remotes on a small tractor #21
UPS delivered the three spool valve from Bailey's an hour ago.
A chief unit sku 220959 at $264. two spools rtc and one rtc with float.
I thought it was -8 orb all around, but the inlet and outlet are -10, I must have confused this valve with some other. I was "shopping" for a while.
Of course Murphy has the last word. I forgot to include the PB fitting in the order.
I did remember to get two spiders for a lovejoy coupling however. ;-)
Alright another question should i plymb the new valce manifold "in series" front end loader power beyond into new valve manifold then out again to feed 3pt lift, or could I put a T with quick connects and feed each valve but i guess at that point i would need to extend the power beyond port to that back because the original FEL would still feed back
And how the heck do you edit a post, I guess I should proofread better first
/ Adding rear remotes on a small tractor #24
The only thing that can be "tee'd" in is a return line. (Assuming your tractor is open center).
You need 3 main hoses to your new valve.
1. Supply. Usually comes from the loader PB
2. PB out. (Make sure PB plug is installed). PB out of new valve feeds 3ph.
3. Return tee'd in to another return.
Basically, if you follow the lone from loader PB to where ever it goes. You are inserting your new valve in this line. So instead of going out the loader PB to wherever....
It goes out loader PB to P port on new valve, then out PB of new valve back to "wherever".
Then add return.
Then add work ports to couplers
Clear as mud?
/ Adding rear remotes on a small tractor #25
What valve did you get?
No valve yet.spending $$ on good box blade first, I figured that was the right way to do it, just thinking i could make a mount and put it right beside my FEL valve and then have less hoses in a tight spot, but i'll probably just go back to original spot on or around ROPs
/ Adding rear remotes on a small tractor #27
Ok. I thought I was loosing my mind.
One post says new valve from Bailey's showed up, then next post is asking about plumbing. So thus my reply.
Then I noticed the post about valve arriving was from CalG.
I literally think there are 3 or 4 threads going on right now (or within the last few weeks) about a remote install. So I am getting 10 kinds of messed up trying to keep track....without going back and re-reading.
Then calG posting about the valve that showed up. I bet he was confused too and thought this was his thread??
Ok, yeah that makes sense now, i was confused a bit on that also
/ Adding rear remotes on a small tractor #29
Sorry To all
Actually, I posted the delivery to me in response to the post that asked "where to get a valve",
and then LD1's response of a selection of possible vendors including Baileys.
I tried to add context by including the description, sku and price.
Alas. good intentions.....
/ Adding rear remotes on a small tractor #30
Sorry To all
No worries. Thats the exact valve I used for my 3 remotes on the MX.
There have been 3 or 4 similar post to this in just the last few weeks that I have replied to. Starting to get blury in my head and I am usually too lazy to re-read the posts. I think I am all good now on whos who and what thread is what.
/ Adding rear remotes on a small tractor #31
Who IS on First? ;-)
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2022 EZ-GO ELITE...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
