Dirt Moving Adding rear remote to CK30
/ Adding rear remote to CK30 #1
Capt. Bob
Middleburg Florida
Kioti CK30 FEL
I want to add a rear remote to my CK30 so I can add a hydraulic top link. Does anyone sell a kit to do this with or do you have to buy all the parts to do so separately? I am sure someone on here has done this. Also if so what is the cost of such a upgrade? Thanks
/ Adding rear remote to CK30 #2
Kioti makes kits for single and dual rear remotes:
Single Remote
Dual Remote
You'll need to contact a dealer to see if the parts are still available for your tractor as a kit at a cost less than the individual parts. If you have an older tractor you may find a new, old stock, kit on eBay. I found a second-remote kit for my 2006 DK on eBay for $300, which was probably the going rate about 10 years ago.
/ Adding rear remote to CK30 #3
I did the double kit back in 2007 for my 2004 CK30hst. The Kioti kits had all parts needed and was a pretty straight forward install. I bought mine from a dealer. The single was around $300 and the second was $350. You can do the single and add the second later if needed. Aftermarket might be a little tough considering how the Kioti kit mounts to the right side of the case just under and to the right of the seat.
/ Adding rear remote to CK30 #4
Go with the Kioti kit. Tough to get everything after market for the same cost and have it even close to the factory system.
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
John Deere 5420 Tractor (A65579)
John Deere 5420...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
