ADDING POWER STEERING TO TRACTOR
   / ADDING POWER STEERING TO TRACTOR #1
redrockerx4
prince george BC
IH
Greetings all,
i am converting my steering to power via a hydraulic steering cylinder with a priority flow control valve which is supposed to give my steering hydraulic priority over my existing front end loader.
i am doing this on an older IH B414. I guess all B414's are older aren't they?
can anyone tell me where the ports are supposed to be connected to on my new priority flow contol valve.
Its a Prince model RD400-R
The ports are labelled as follows
IN
PRIORITY
EXCESS FLOW
TANK
i am trying to plumb this into my existing front end loader controls.
If anyone could perhaps post a rough sketch or perhaps just an explanation, this would be greatly appreciated.
   / ADDING POWER STEERING TO TRACTOR #2
Logically, flow from the pump goes to the IN port of the RD400R first.
http://www.princehyd.com/Portals/0/products/valves/catalog/valvesRd400.pdf
http://www.surpluscenter.com/Instruct/I9-4158-15.pdf
There is a relief for the priority circuit and the relief output goes to tank. It is factory set at 1500 psi.
The number to the right of the 400R, is the GPM for the priority flow. This will determine how fast the steering will operate.
Priority goes to the steering control valve. You always want steering.
If your priority valve is 2 GPM and the hyd pump is a 10 GPM, then the priority will always get the first 2 GPM, and the FEL will get the rest of the pump flow. Pump volume is determined by the engine rpm. At idle or slow and steering, you may not have flow to the FEL.
Excess flow goes to the IN port of the FEL valve.
Tank goes to any tank return line.
That is my interpretation.
This is a sample pic for a IH, not yours.
http://www.powersteeringkit.com/inter.html
Thanks J_J,
Your interpretation looks pretty good to me.
i was under the false impression that the priority valve inlet was in parrallell with the inlet of the FEL controls
i am going to move my B414 into the 19 century now, man is it going to be a pleasure to drive then. Hopefully i can then convince my wife to drive the tractor.
regards
redrocker
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
