adding power steering to 950
/ adding power steering to 950 #1
jacksdad
I am looking at buying a 950 2wd w/ FEL and approx. 1800 hrs. The tractor does not have power steering and i don't know if it can be added or if i should keep looking till i find it.
i will be using the tractor to bush hog and mow approx. 3 acres, maintain a medium sized veggie garden and, initially, move around 10-20 loads of fill to get my grading right (we are having a house built). It will also be used to maintain about a 160' driveway.
i thought about the 790 but it's considerably more expensive (i believe i can get the 950 for $6k) and probably not worth the money for power steering and 4wd. Our lot is very flat (maybe a 2-3' elevation change over 400 feet).
So can power steering be added? Is it expensive? Am I ok with 2wd?
Thanks for the help,
Erik
/ adding power steering to 950 #2
I have a 1984 JD 950 MFWD (4wd), FEL, and PS. I have seen a used power steering kit on ebay a couple times, but not lately. Not sure what it would take to actually add it on.
As far as the 2wd, that may be a problem in dirt work. I have ag tires, but my traction is not that great in 2wd, even with the diff lock. Significant difference in 4wd when trying to push into a pile of dirt to load the bucket. Now I will say that my rear tires appear to be the original and the rubber seems to have hardened and is pretty slick. I have new tires on the front and there is an obvious difference. That may be part of my problem.
thanks bb. i will watch out for a cheap kit.
i bought the tractor and love it already! entire thing was sandblasted, primed and repainted and looks great. i paid $6,500 and think i got a very fair - excellent deal. didn't steal it, but happy with the price.
do you know if the 950 will pull a 7' finish mower or should i stick with 6'?
thanks,
erik
/ adding power steering to 950 #4
Yeah. I really like my 950 also. Don't know about the finish mower. I run a 6' rotary cutter on mine and it cuts pretty tall and thick grass fine. I would think it would run a 7' finish mower OK for cutting short grass.
As a side note. The muffler on mine was loud and badly rusted and rattling inside. I let it go for several years, but replaced it last month. The result was a significant boost in HP!!. I guess it was restricting or otherwise messing up the exhaust flow. Made quite a bit of difference mowing tall grass.
2015 VOLVO VN (INOPERABLE) (A65643)
2015 VOLVO VN...
2010 GMC 3500, Crew Cab, 2WD, Dually (A62679)
2010 GMC 3500...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Metal Goat Family Statues (A64127)
Metal Goat Family...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
Winchester 20 Gun Safe (A65579)
Winchester 20 Gun...
